Fog Light
Old Apr 10, 2009 | 08:37 PM
RusAcura's Avatar
Fog Light
Hey, i'm new to Acurazine and was wondering if someone can help me out with my fog light problem. i just bought the car and it is awesome, minor work being put into it next weekend (tint, debadge,alarm,navi,sub). However the problem i have is that the stock fogs are so weak and yellow. What can i do? i would like to have stong white light. i will post pics next week after the work.
Old Apr 22, 2009 | 06:43 PM
Samsung123's Avatar
I have a 2003 CL Type S 6 speed and would like to do the same. Model 2003 did not have the running lights so I plan on installing them soon and I agree, a 5 watt bulb is not much light. Have you found or heard of any ideas? Do you have some pics?
Old Apr 22, 2009 | 08:02 PM
aznboi2424's Avatar
use the search function please. they are called road lamps not fog lights on our cars. best bet is to use some polarg bulbs, they are brighter and whiter.
Old Apr 22, 2009 | 10:22 PM
blackasscls's Avatar
Buy smt LED's the size you need for the lamps is 194, I am unsure if I can post this but I got mine from V-LEDS.com. They are as bright as the stock HID's with only a tiny bit bluer tint to them
Old Apr 23, 2009 | 08:49 PM
CLSLV's Avatar
Piaa 19224 or Polarg M6, better yet hid conversion with 3000K.
Old May 10, 2009 | 01:30 PM
Chuco's Avatar
Driving lights install on 03 cl-s
Do a search, there is a lot of info out there on how to do it. Be careful though, one idiot said to tap the wire to power the lights from the headlight. This will cause the balast to blow. I did the install myself because I am familiar with 12v. Use a relay to power the driving lights. Tap the wire that gets power when you turn on the headlights to activate only the relay. Power the relay and the driving lights with a wire directly from the battery. It is a very simple install. Do your research, but wire it properly and use relays and inline fuses. If you want precise detailed instructions on how I did mine, email me directly. I would be happy to inform you.
Old May 10, 2009 | 09:22 PM
aznboi2424's Avatar
umm the OP's car has the road lamps already installed on them. he was mearly looking for a way to obtain better light output from them.
Old May 15, 2009 | 08:43 PM
Samsung123's Avatar
Chuco,
I would like some assistants on wiring the driving lights. I have purchased the L and R lights, both sockets and I plan on purchasing the TL fog light switch. Wiring diagram would be great, what type of relay switch, what size of in line fuse and the brand name/part number of the light bulb.
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
