Does the cl have LESS tranny problems than the tl?
Old Jul 27, 2009 | 06:01 PM
FoRMuIaz's Avatar
Exclamation Does the cl have LESS tranny problems than the tl?
still debating on which car i should get.
Does the 2001 cl-s have less transmission problems by the 2002 tl-s?
or does it have more problems.
Old Jul 28, 2009 | 01:12 AM
aznboi2424's Avatar
Same amount of problems. The tranny is the same, even interchangable i.e: i have a TL-S tranny in my CL-S
Old Jul 28, 2009 | 02:48 AM
FoRMuIaz's Avatar
oh ok,Would you recommend the cl-s or tl-s?
or are there too many problem with the car.
Old Jul 28, 2009 | 03:38 AM
aznboi2424's Avatar
depends if you want a coupe or sedan.
If you chose a TL or 01/02 CL, then get one that still has the tranny warranty still in effect.
If you want a CL without the tranny problems, get the CL-S 6speed.
Old Jul 28, 2009 | 01:53 PM
FoRMuIaz's Avatar
probably going to get the 01' coupe AT; The guy that i want to buy from he got the tranny replaced at 107k and now its 137k
selling for 6.5k,is tht a good deal?
Old Jul 28, 2009 | 01:58 PM
aznboi2424's Avatar
not too sure. check KBB and such. Also run a car check on it.
Drive the car and make sure the tranny shifts smoothly, ask for documentation of tranny replacement. And only buy it if he did the 105k service (plugs, timing belt, fluids, etc) because that sesrvice alone will save you nearly 1k.
Old Jul 28, 2009 | 02:06 PM
FoRMuIaz's Avatar
ya i havent gone for a test drive yet but when i go ill be sure to check.
thanks for the quick response and the advice
Old Jul 28, 2009 | 08:18 PM
civicdrivr's Avatar
Well, to answer your question, more TLs were sold then CLs, so yea, the TL has more tranny problems
Pham Alvan
May 18, 2021 06:48 AM
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
