Desperately need advice!!
Old May 16, 2020 | 06:14 PM
Atlee Zabel's Avatar
6th Gear
Just bought the 2003 Type s 6 speed car for $1,000 from a teenager. Said he just didn't want to put any more money in it, just swapped engine into it and wouldn't go above 2000 RPM. Scan codes before I bought, just one crankshaft position sensor code so I figured as easy as that. Come to find out, the engine swapped into it was from an automatic. What's my easiest route to get this car out of limp mode and running well?
Old May 16, 2020 | 09:30 PM
you need to make the automatic J32A2 six speed compatible with the following parts from a CL-S6 J32A2:
front head cam pulley, cam sensors & sub harness, backing plate
TB drive pulley, crank sensor & sub harness, TB stopper plate
Old May 17, 2020 | 06:34 PM
6th Gear
So so if I can't find another CLS6 engine to take parts from, there's no other way?
Old May 18, 2020 | 06:38 AM
Pretty much.
According to the OEM parts websites, the only parts above that have not been 'discontinued' are:
TB drive pulley
Crank sensor assembly
https://www.acuraoemparts.com/v-2003...6-speed-manual
You should check the 'teenagers' work he may have all the parts present. There may just be something else wrong?
Good Luck!
Old May 28, 2020 | 11:50 PM
6th Gear
Originally Posted by zeta
Pretty much.
TB drive pulley
Good Luck!
​​​​​​oh we checked lol didnt have any of the parts present lol was a teenager I bought from but he had a shop swap motors. Neither kid nor shop knew about the difference until the old motor had already been scrapped. they just thought a J32A2 was a J32A2.
But anyway, I lucked out and found everything that should have been swapped the first time, and now have it all installed...
​​still only go 2000 RPM 🤢 still po335 cel. Idk what the problem is. I've checked and double checked and triple checked, I have every part that is supposed to be on the engine to be manual compatible installed but it didn't change anything. Timing is perfect. To me, it has to be wiring problem now
Old May 29, 2020 | 06:11 AM
p0335 is the pulley side crank sensor. Check / replace the transmission side crank sensor. It's been known, when a p0335 MIL triggers for these 6-speeds that you have to check the opposite sensor.
Check out the threads below:
https://acurazine.com/forums/second-...e-code-968203/
https://acurazine.com/forums/2g-cl-p...-p0336-957910/
https://acurazine.com/forums/second-...-p0335-982111/
In addition, do you know if the 'shop' installed the correct flywheel? You need an OEM or LUK DMF063 equivalent with those triggers for that sensor to function:
https://www.rockauto.com/en/moreinfo...0c2wcCrg%3D%3D
Good Luck!
Old May 29, 2020 | 02:37 PM
StreetKA's Avatar
yeah check all that info and report back,
when i did the auto engine swap i did the write up and everything went smooth
Kosova Canada
Mar 14, 2018 12:35 AM
GaryCT
1G CL Problems & Fixes
May 19, 2017 06:41 PM
Kwizzle
2G CL Problems & Fixes
Jul 24, 2015 05:21 PM
edesoto
May 8, 2009 07:22 PM
sauceman
Jul 14, 2006 05:01 AM
