Dash light out
Dash light out
I was hoping someone could give me more information....
My clock light is out in my dash but the clock works fine. Im thinking its not a blown fuse because all other lights work. Has anyone had this problem before? It can be annoying at night time. What does it take to replace a bulb (if thats the problem)? I dont want to take it to Acura Im just looking for someone to help me get that light working again
thanks
thanks
I have the same problem, I am looking through the helm's manual and it is very confusing...I haven't really gotten a chance to look at the fuse box but I think it would be the drivers side under dash fuse box #9. I will check it when it is light out.
Thats what I would have thought but according to the circuit diagram the clock function and the clock back light are different fuses....that being said I checked my fuse and it wasn't blown, so I still don't know what happened.
having to take off the dash just to change a bulb is insane. Ill run my car into the ground before I take it to the stealership to replace a damn bulb.
Honion- let me know how everything goes because Ill be doing the same thing as you
I had this problem last month. Gotta take out the dash to reach the bulb. But the bulb that I replaced it with is not that bright. It use to be as bright as the stock headunit's light. BLACKCLONDUBZ, is your light as bright as the rest? If so, what kind of bulb did you use and where did you get it?
i have roughly 67K on my CL and the bulb went out a few months after a bought the car.
words can not describe how much I enjoy turning on the interior lights just to check the time! No way will I bring my non-warranted car to acura to fix a damn bulb...i figure since Ill be removing the dash I might as well buy a new brushed aluminum one to replace it
lucky me
Believe it or not I decided to just tap on the clock for the hell of it and the light came on...I guess something just got jiggled loose when I took apart the console to install my ipod.
haha, looks like we have one more person to enlighten about the magic of the "smack it" method.
give it a nice hard rap directly underneath and overtop, if it doesn't light up THEN you need to change the bulb.
Just two screws on the top of the bezel - thats the only thing that holds it. Drop your steering whell all the way down and simply rip out entire gauge trim, disconnect few plugs and twist that damn bezel - if you take it out its pain in the butt to get it back in. Little flat head screwdriver should do a bulb replacement. Once you do it your second time will be a snap. Do not let those stealership suckers rip you off
mada51589
05-03-2022 08:54 PM
BoricuaTL
04-08-2016 01:08 PM
Greengecko
09-16-2015 08:19 PM
