Dash light out
Old Jan 2, 2006 | 06:57 PM
MSW 6SP's Avatar
Dash light out
I was hoping someone could give me more information....
My clock light is out in my dash but the clock works fine. Im thinking its not a blown fuse because all other lights work. Has anyone had this problem before? It can be annoying at night time. What does it take to replace a bulb (if thats the problem)? I dont want to take it to Acura Im just looking for someone to help me get that light working again
thanks
Old Jan 5, 2006 | 04:19 PM
MSW 6SP's Avatar
somebody? anybody? The last thing I want to do is take my car to the dealership to fix my problem...
Old Jan 16, 2006 | 05:14 PM
honion's Avatar
Yeah, I'm a girl
I have the same problem, I am looking through the helm's manual and it is very confusing...I haven't really gotten a chance to look at the fuse box but I think it would be the drivers side under dash fuse box #9. I will check it when it is light out.
Old Jan 18, 2006 | 10:31 AM
MSW 6SP's Avatar
Im no electrician but if it was a fuse problem wouldn't there be more lights out then just our clock? Thanks for looking into this and letting me know
Old Jan 18, 2006 | 08:53 PM
honion's Avatar
Yeah, I'm a girl
Thats what I would have thought but according to the circuit diagram the clock function and the clock back light are different fuses....that being said I checked my fuse and it wasn't blown, so I still don't know what happened.
Old Jan 19, 2006 | 09:20 AM
BlackClonDubz's Avatar
i had the same problem on my CL....upon taking it to the dealership they said that the bulb is blown but it cost alot for them to fix it...so i simply took off the dash and installed a new bulb that was about $7...
Old Jan 19, 2006 | 01:40 PM
MSW 6SP's Avatar
having to take off the dash just to change a bulb is insane. Ill run my car into the ground before I take it to the stealership to replace a damn bulb.
Honion- let me know how everything goes because Ill be doing the same thing as you
Old Jan 22, 2006 | 01:29 AM
BangBang617's Avatar
I had this problem last month. Gotta take out the dash to reach the bulb. But the bulb that I replaced it with is not that bright. It use to be as bright as the stock headunit's light. BLACKCLONDUBZ, is your light as bright as the rest? If so, what kind of bulb did you use and where did you get it?
Old Jan 22, 2006 | 02:53 PM
yea it shows regular as far as i can tell. I bought the bulb from the acura dealership parts dept.
Old Jan 25, 2006 | 09:19 AM
welphd's Avatar
My clock light ran out last night. But all other lights are fine. This is 2003 CL at 56K miles.
Old Jan 25, 2006 | 09:22 AM
welphd's Avatar
Can someone post the procedure for changing the bulb? I can't believe acura put such a short life bulb in there. thanks!
Old Jan 25, 2006 | 09:37 AM
welphd's Avatar
Just called Wayne Acura. They charge $86 to change the light. Uggg! Acura sucks!
Old Jan 25, 2006 | 05:40 PM
MSW 6SP's Avatar
i have roughly 67K on my CL and the bulb went out a few months after a bought the car.
words can not describe how much I enjoy turning on the interior lights just to check the time! No way will I bring my non-warranted car to acura to fix a damn bulb...i figure since Ill be removing the dash I might as well buy a new brushed aluminum one to replace it
Old Jan 25, 2006 | 06:01 PM
Beelzebub's Avatar
I just had the dealership do it as my car is still under warranty.
Old Jan 25, 2006 | 06:36 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
You don't have to remove the entire dash, just the plastic around the HVAC controls and gauges, right?
Old Jan 27, 2006 | 09:55 PM
honion's Avatar
Yeah, I'm a girl
lucky me
Believe it or not I decided to just tap on the clock for the hell of it and the light came on...I guess something just got jiggled loose when I took apart the console to install my ipod.
Old Mar 22, 2009 | 02:14 PM
2rhs94705's Avatar
2001 TL, 31000 mi. Clock back light off. Clock works. Fuses check OK. Is this a simple bulb replacement? Or an entire clock? Looks like entire dash needs removal to access. How difficult is dash removal?
Old Mar 22, 2009 | 02:35 PM
EliteDemon's Avatar
The TARDIS is my
haha, looks like we have one more person to enlighten about the magic of the "smack it" method.
give it a nice hard rap directly underneath and overtop, if it doesn't light up THEN you need to change the bulb.
Old Mar 23, 2009 | 11:09 PM
celynka's Avatar
Sundance Gold in
Just two screws on the top of the bezel - thats the only thing that holds it. Drop your steering whell all the way down and simply rip out entire gauge trim, disconnect few plugs and twist that damn bezel - if you take it out its pain in the butt to get it back in. Little flat head screwdriver should do a bulb replacement. Once you do it your second time will be a snap. Do not let those stealership suckers rip you off
mada51589
Jan 9, 2025 04:40 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Rob144
Sep 21, 2015 08:18 AM
Greengecko
Sep 16, 2015 08:19 PM
PortlandRL
Sep 14, 2015 12:01 PM
