Cleaning headlights
Similar to member eneffex, I wet sanded starting from 800 up to 200 then polished it. Made a huge difference! If the oxidation is bad then definitely start with a lower grade (less sand per square inch) and work your way up!
Hope this helps!
Andrew
Hope this helps!
Andrew
Whats up with RDX owners?
So wet sand with 800, then 1200, 1500, 2000, followed by Meguiars Plastx. Seal/Wax them every three months or so to protect them.
civicdrivr (02-08-2012)
shifting at 7k
there's a good write-up here, check post #12 on this thread:
https://acurazine.com/forums/2g-cl-2001-2003-50/fresh-wash-wax-wetsanded-headlight-pics-484296/
Right, I just listed the grits I used, I figured common sense would be that you start with the lowest.....but I guess common sense isn't so common these days.
its also worth noting these grits are somewhat arbitrary depending on the condition of your headlight, obviously, topic start with lower grits for more pitting and yellowing...use discretion
Master of Mountain roads
I do custom painting of motorcycles and so I always have plenty of sand paper around here in various grits. I have other finishing materials as well of course and so when it came time to clean up my headlights I just used what was at hand.
After all the miles (224k) my light covers were scratched and had the usual stone chips, so I started sanding with 400p grit (with block) to take out the flaws, then I went immediately to 1000p grit to to take out the sanding scratches and then hit them with 1500p for my last sanding. Then I put a medium pad on my buffer (Makita 9227C) and using 3M Perfect-It II made them like new in about a minute apiece.
AmplifiedDetails
09-24-2015 02:55 PM
