Check engine light...Whats this code???
Old Feb 13, 2008 | 04:24 PM
Oh1TypeS's Avatar
Question Check engine light...Whats this code???
I got the codes run and it said it was the auxiliary emission control. the code is
P1456
Any one know exactly what this is..???
Thanks in advance!
Old Feb 13, 2008 | 05:27 PM
fuzzy02CLS's Avatar
The exact code is....
Evaporative Emission Control System Leak Detected (Fuel Tank System)
The manual goes into a whole procedure to test the system out, but It's likely a bad gas cap, or Bad purge valve.
I got the same code when my purge valve died. Not just ticking, but it was stuck in open loop & would not close.
Old Feb 13, 2008 | 07:20 PM
Oh1TypeS's Avatar
What am I looking at as far as cost/ part number?? Thanks a lot for your help
Old Feb 13, 2008 | 08:49 PM
fuzzy02CLS's Avatar
Research it. It's covered in the FAQ & there are many posts on the purge valve. It's a $50 part & 5 minutes to put on.
Old Feb 13, 2008 | 09:40 PM
NSXNEXT's Avatar
First thing first. Remove the gas cap then put it back on and tighten it till it starts clicking. I would disconnect the neg battery terminal for a few minutes. Then check to see if the CEL comes back. More often than not it's just the gas cap not being screwed on tight enough.
Cost = $0
Old Feb 14, 2008 | 08:05 AM
Oh1TypeS's Avatar
I'll try that tonight. Thanks,
Billu99tl
Sep 13, 2015 11:30 AM
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
