a/c fan and cooling fan not working
Old Apr 7, 2021 | 10:04 PM
dashaint's Avatar
hi yall, so it seems i smashed my 2003 cl type s, into a truck and its bumper hitch... no one got hurt, but it hit it hard enough to push radiator fans into engine and crack the shrouds their in.
the fans worked fine prior to the accident. air and cooling fans.
so, i replaced the radiator and fans .. but so far neither ever kicks on. the a/c never kicks on now from the controls. and the cooling fan.. not sure what temp it kicks on at, but i got it up to running temp...almost halfway on temp guage..and never came on.
everythings connected, ive swapped out the relays.. no luck. looked for related fuses, havent located any. theres a couple of other small other relay boxes under the hood, not sure what those control, anyone know?. ive even connected my prior fans up to see if the others were bad, no change.
on the a/c, i need to check the a/c coolant pressure, it could be totally out.. maybe that's the problem with that fan, but doesnt the a/c fan have to be sensed to be running, or air going across the coils before the compressor will kick on?. i'm in need of good advice..
Old Apr 11, 2021 | 06:40 PM
dashaint's Avatar
it was just low on freon, charged it up, found a leak in a/c radiator.. both fans working as should. thanks.
jliu6789
Jun 21, 2014 10:18 AM
dan lazer
Apr 2, 2011 04:17 PM
zerep6
May 6, 2008 07:04 PM
NightRider
Aug 1, 2007 05:40 PM
