Idle caused by bad gas?
Old Apr 5, 2021 | 12:25 PM
Jason Holt's Avatar
Jaydedbylife
Help with 2002 CL type s
I have a 2002 Acura CL type s that had sat for a year and when I went and started it it was idling fine for about the first three or four minutes then it start idling high and going low and going high and going low I was wondering could that be because of bad gas I didn't do anything with the gas for a year
Old Apr 13, 2021 | 08:42 PM
619rcr's Avatar
idle surge is normally something related to a vacuum leak from a hose or bad gasket such as throttle body. it may have been just a coincidence that the gas is old. that would more likely cause a misfire or stalling. you can try spraying some brake clean around the tb or any openings on the intake. a torn hose or a bad seal might pull in the vapor and change the idle.
good luck.
CBloc-CL
Sep 18, 2006 10:07 AM
weedahlong
Mar 22, 2005 09:52 PM
ghost_masterCL
Dec 10, 2004 08:39 AM
davo-cls
Jun 8, 2004 05:17 PM
