Excessive Fan runnage!
Searched and couldn't come up with anything...
Although it is Summer, my fan seems to be running nearly constantly whether driving or parked. Is the engine really that hot all the time that it needs the fan? Could this point to an underlying issue? Thinking about having this checked out.
Not to scare you, because it's very possible your low coolant is what's causing your fan to run continuosly, but...
...Watch your coolant level closely after you top it up. It's a closed system, so it shouldn't be dropping very fast, if at all. If your coolant level drops, check for leaks under the engine, coolant hoses, etc. If it's going down and you can't VISUALLY SPOT a leak you may be leaking coolant into the engine via the head-gasket, or another gasket. This is obviously a big problem.
I had a hose spring a leak last summer causing my engine to overheat and head-gasket to go - NOT FUN and NOT CHEAP.
Hope that helps.
Hope that helps.
