2001 Power steering belt
Old Jun 29, 2010 | 01:24 PM
Blainn's Avatar
9th Gear
Hey all, can you point in the right direction for a DIY or FAQ to change the belt on a 2001 CL s type? Looks to be a PITA and the shops want $175 to do it.
Thanks!
Old Jun 29, 2010 | 10:17 PM
pits200's Avatar
You're going to have to take off the accessory belt to put on the power steering belt.
1.) I think it's a 14mm wrench on spring load pulley and push back towards cabin of car. (This will let you remove the accessory belt.
2.) Now that this belt is removed, you will want to look for the side motor mount bracket and remove the two bolts that are near the power steering pump.
3.) undo the 1 power steering pump bolt, I think its a 12mm but I can't remember.
4.) Loosen the nut on the power steering adjuster rod thingy. This will allow the power steering belt to have some slack.
5.) Remove ps belt and put new one on.
6.) Reverse to put back on.
Old Dec 14, 2011 | 11:38 PM
derosee's Avatar
Are these two engine mount bolts easy to remove?
Old Dec 15, 2011 | 03:58 PM
civicdrivr's Avatar
They should be, but you also run the risk of snapping one of the bolts in the bracket like what happened to me. But I think the previous owner had the car in for service and they overtorqued it.
Old Dec 22, 2011 | 03:13 PM
derosee's Avatar
Thanks. Mine's overtorqued too. I'm literally drilling one of the two bolts (14mm) out. Still no luck.
Old Dec 24, 2011 | 12:58 PM
StreetKA's Avatar
you should support engine from the bottom that should make it easier spray some pb blaster it should go loose... lift the engine slightly so it will remove some tension on those bolts
Old Dec 27, 2011 | 10:10 AM
derosee's Avatar
Thank you, that makes sense.
Old Dec 27, 2011 | 10:38 AM
StreetKA's Avatar
You're welcome. Now you should thank my post. Lol. Good luck
Old Dec 27, 2011 | 11:30 AM
civicdrivr's Avatar
I thanked you for him. Happy, you thank whore?
Old Dec 27, 2011 | 11:39 AM
StreetKA's Avatar
Look who's talking
Old Dec 27, 2011 | 11:46 AM
civicdrivr's Avatar
Yikes
May 3, 2021 04:29 PM
mike from annapolis
May 7, 2017 08:21 PM
nash3222
Sep 10, 2015 09:46 PM
asahrts
Sep 4, 2015 05:55 PM
