03 CLS 6M High Speed Vibration
Old Feb 2, 2009 | 08:35 AM
Cgally's Avatar
Greetings fellow Cl owners. My name is Chris and I live in North Redington Beach in central Florida.
Anyway... as the title states, I'm chasing down a strange vibration. I have replaced front, rear, and side mounts as well as the two trans mounts and both torque dampers. The vibration is pretty bad under WOT from 50 and up. I just bought new tires which were balanced so I guess that would eliminate a bent rim.
Any ideas????
Thanks!
Old Feb 2, 2009 | 11:55 AM
civicdrivr's Avatar
Ball joints, tie rod ends, axles. Check those.
Old Feb 2, 2009 | 12:23 PM
alxmlr789's Avatar
*6MT*
I'm chasing the same exact vibration. 50-65 mph. normally 65-90 is fine though. ONLY under acceleration.
I just bought some new axles, so i'm hoping thats it!
Old Feb 3, 2009 | 12:38 PM
Cgally's Avatar
Thanks. I've pulled the passenger side axle out for inspection and it looked perfect. Also, the car has been on the lift and nothing appeared loose or abnormally worn. I just hit 100k last week. How long should ball joints last?
Old Feb 4, 2009 | 02:13 AM
victorvu's Avatar
Check the upper ball joint mine is gone i have to get it replaced exact same symptom from 48-58mph vibration is crazy under wot
Old Feb 4, 2009 | 11:47 PM
alxmlr789's Avatar
*6MT*
I fixed my axles today, both of them looked perfectly fine (cept for the CV boot on the drivers side)
Most of my vibration/wobble is gone. ALL of it is gone under acceleration. I think the remaining vibration is from my tires, the ones on my TL rims are prettty old.
Old Feb 5, 2009 | 03:37 PM
Cgally's Avatar
what type of axles did you buy? They are balanced when they are manufactured. Did you happen to notice a balancing weight missing?
Old Feb 5, 2009 | 11:17 PM
alxmlr789's Avatar
*6MT*
I bought the GSP axles from advanced auto parts. They come with a lifetime warranty.
I havent noticed anything about a balancing issue, they seem to be doing their job 100% correctly.
Old Feb 25, 2009 | 03:56 PM
Cgally's Avatar
Finally.... It was the other axle. My car doesn't shake anymore!!!!!
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
Sep 17, 2015 09:01 PM
Sixers12
ILX
Sep 6, 2015 07:54 PM
