03 CL-S 6 speed reverse issues HELP!!
Old Oct 1, 2011 | 02:12 AM
tla11384's Avatar
I am having issues occasionally shifting into reverse. It doesnt always want to engage all the way. I either have to pump the clutch a couple time (works most of the time) or I have to shift into 1st and go ahead a little and then it shifts into reverse find after that. Any Ideas why?
Old Oct 1, 2011 | 05:29 AM
StreetKA's Avatar
We need more info about your car. Is modified ? Having issues shifting into other gears ? First thing i would check is clutch fluid level and cables.
Old Oct 1, 2011 | 10:48 AM
fuzzy02CLS's Avatar
Reverse has a lockout syncro so you can't shift into it accidentally. Having to pump the clutch once or go into 1st gear is common with this type of lockout device. I've had to do it on occasion too. If all other gears appear to be normal & there's no grinding I'd look at the clucth fluid level, & if that was ok I'd change your trans fluid to the new Acura reformulated MT stuff.
Old Oct 1, 2011 | 11:27 AM
StreetKA's Avatar
+1
Old Oct 1, 2011 | 11:50 AM
tla11384's Avatar
Is the clutch fluid different from the transmission fluid? Where can I check the clutch fluid level? I just bought manual transmission fluid from the Honda dealership and changed it about 3 weeks ago. No effect on the reverse engaging better. As far as I know everything is stock on the tranny.
Old Oct 2, 2011 | 03:09 PM
civicdrivr's Avatar
The clutch master cylinder is to the right of the brake master cylinder on the firewall.
On ALL the Hondas I have driven, some twenty years old, others brand new off the lot, reverse is difficult to get into. I always put it into third then into reverse - not a single problem since.
Old Oct 3, 2011 | 05:38 PM
SimonCL-S6's Avatar
hmmm, i never had trouble going into reverse, or any gears...Are you completely stopped when going into reverse?
Old Oct 3, 2011 | 05:47 PM
combat mediC's Avatar
I put 200k on my CLS-6, never had that issue... Probly the syncro is getting stuck
rockyboy
Aug 4, 2024 10:35 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
carz0159
Sep 20, 2015 06:11 PM
Dunnik
Sep 14, 2015 02:56 AM
Mike Bertram
Sep 10, 2015 09:27 AM
