$2K ABS Modulator or $4 fuse?
Had the ABS, VSA, and ! lights on a few weeks ago. Took it to the dealer and was told that codes 51-1 and 83-1 were stored in the computer and that I needed a new ABS Modulator. $2040.00.
Finally got the idea to check out the fuses, and found that the 30 amp ABS fuse was blown. Put a new one in, started it up, and all three warning lights cleared after about 20 seconds. Did a few hard stops, and ABS is definitely working. Now, just wondering if my joy will last, or if the lights will come back...
PS- long time lurker, first post. I appreciate all the great info on the site (how do I change that cabin air filter....ahh, remove the glove box - thanks!)
i wouldn't recommend getting another abs modulator. Those don't usually go out that easily. Your fuse was probably just blown so you should be good to go. Just check if all the sensors are connected correctly
for a guy with one post, you sure are making progress.. lol and yes I'd definatly let that dealership know how retarded they are.
Just think if they had made u pay and then fix the fuse as well so it actually works and you'd THINK they were right... cause they may have known all along and we're trying to play you.
Everything is a scam on this planet... it's a question of how much.
Jamus22
Jun 11, 2023 10:08 AM
Acura604
20
Aug 5, 2017 12:55 AM
SUPRMN84
Oct 7, 2015 09:46 PM
ripit
Sep 26, 2015 06:19 PM
