StreetKA's CLS6 Thread
#321
American made. $140 each (at the time I bought mine) with a core return of your original OEM axles. They provide UPS return labels when the replacement axles are sent. The new axles have the rubber shaft balancers as well. They looked like a work of art when you get them, high quality. lol
http://www.raxles.com/
#322
Whats up with RDX owners?
IIRC Advance Auto sells decent axles too. Should have a lifetime warranty as well.
Im running axles from Auto Zone but they dont have the rubber balancers.
#324
IIRC it does.
#326
Didnt it come with instructions?
#327
not at all but it cant be much different than this one
http://www.pspectuning.com/0206R_tutorial.php
#328
That's the instructions I used. Pretty straight forward install.
#329
i did the shifter today and i must say its amazing ! it makes me want to drive the car much more its really fun now ! one of the best mods for the car
i had to trim the shifter a bit to make it work for the shifter lowest position
![](http://i772.photobucket.com/albums/yy9/StreetKa/d6a4efc6.jpg)
![](http://i772.photobucket.com/albums/yy9/StreetKa/e5dbc93e.jpg)
![](http://i772.photobucket.com/albums/yy9/StreetKa/605597f2.jpg)
i know its height adjustable but how do you adjust the throw ?
#335
Regional Coordinator (Texas)
damn that looks good. i wish i had gotten a short shifter too.
and u made the right decision going with black di-noc. i think it looks a lot better than graphite.
i actually want to switch out to black now too.
#336
#337
ordered parts for timing belt service and also new slave cylinder
helms manual came in mail this thing is heavy...
ordered swaybars links front rear and bushings also TB spacer and ss clutch line.
what im looking for is a stock CL/TL Type S intake manifold
#340
B A N N E D
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
BUT i will say i have cleaned a couple of edges on my manifold, but that was more just so there was no more 1/16" or bigger lip, and i just blended the two parts together, so it was smoother; and i had used a grinding stone i had laying in my tool box, so nothing special (compared to sandpaper, i probably would say it be in the "120 range", not exactly the smoothest...)
#343
its JTC a PSPEC knock off since i could not get PSPEC anymore. As for di noc i know thats probably 36x48 should be enough if u wont do steering wheel... maybe you'll be able to squeez steering wheel too idk.
#344
I think the blacked out trim looks great
#347
im working on new grill project that will be something new and i think nobody has ever done it. keep finger crossed for good results... i think i will try tape that chrome trim again and see if i like it maybe its gonna grow on me.
i need a new battery bad ! died today on me at the meet what a shame![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
got a friend that localy will let me try my wheels on his tl type s so that way i will now for sure that the will or will not fit bbk
painting headlight housings this weekend too
#350
Yesterday i installed p2r IM thermo spacer and TB spacer as well also i found that rubber conection between intake and tb is broken. Right now car is running like never before. But there is a thing i messed up. While i was making IM top cover bolts tight i broke one of them and i think its leaking right now i will try to take rest of the screw out once the weather will be a lil nicer. Car at low throttle feels like is misfiring but no cel so far. At WOT its like a rocket now. Im pretty sure its leak
If i cant take that screw out im gonna have to buy new intake manifold. Then im gona p&p it.
#354
I have the Bilstein shocks which are very comparable to those. I am now riding on D2 coilovers and I fucking hate them.
Haven't hit the track yet with the D2's but driving daily tells me I won't grip as much as my spring/shock combo.
If you aren't looking for performance and just want a nice drop and shocks that will last long, PULL THE TRIGGER. I'm on my sixth year of owning the bilsteins with track abuse..still not blown.
The D2's I just got and I feel they are going to blow with how much I'm planning to hit the track this year.
Next setup I will try will the be the AMRs.
#356
100k on the clock
i need some advice. i want upgrade suspension im considering Koni yellow as they have adjustable dampening and you can lower spring seat for 20mm the other option is i found used tein basic coilovers for pretty much same price what you think ? i know tein basic doesnt have adjustable dampening but its nice to be able raise and lower your car as you like
