nspec's 01 CL-S thread
#81
Regional Coordinator (Texas)
may be later on. it'll be another mission to make this one work with the 6 speed ABS unit.
doing some work on it (and driving it around)
RWD for sure, later on.
#85
i cant remember the exact model number.
i think they're 14832.
here is a clip i found of those mufflers, dont know if its a member here.
http://www.youtube.com/watch?v=Anw31QEpk2I
#86
im now thinking about doing some body modification when i do the lip kit (has a little to do with future plans of RWD conversion)
#92
Whats up with RDX owners?
x2 and what transmission?
#94
Cool. The TC is solid rear axle though, no? What about the LS? Arent thouse IRS?
#96
I wasn't wondering how you'd weld it in, I was wondering why you'd want a solid rear axle. I can understand if its going to be a strip-only vehicle, but for a street car Id prefer a IRS for handling purposes.
Have you thought about an S2k rear end? I know the diffs cant handle a whole lot, but there are aftermarket parts out there for it. What about 350Z/G35?
And most importantly, what tranny were you planning on running?
#97
LMFAO. we were just fucking with you guys.
David started off by mentioning the Town Car and i just started playing along.
here's whats in mind:
2JZ w/ Getrag, as far as rear end goes, it'll be decided later, but just to make it work, ill start off with a 240 rear end (there are too many of those availble)
For the floor and the rear suspension, i'm also looking at 240s. also considering 1st gen SC.
i'm not gonna go all out on it either so i'll keep the parts under a budget, then one by one, do upgrades on those parts.
#104
That kinda makes me sad that you are going to swap in a 2JZ. It just seems too easy. Id much rather keep the J.
Either way, it will be an interesting project if you do pull it off.
#105
Gonna cost to catch up
#108
got to spend a couple of hours on the lip today.
so far its all molded, not glue used so far. it was cut into two pieces only. i made a mistake putting a cut on the passenger side corner
The way its going so far. I think i'll be able to make it remove able and not have to glue it to the bumper. Ran out of time so this is how it is right now. tape is there to reinforce the corners.
#110
Goddamnit. I guess Im next in line for the TL kit /
#115
I should be banned for lots of things
#119
x2 But maybe its just the angle, the rear of the lip near the wheel wells looks like it needs to be dropped a hair, or the front of the lip needs to come up. It appears to be a bit slanted compared to the body line in the bumper.
