2G CL Frequently Asked Questions No New Threads Please.
DIY Ballast replacement
Old Feb 2, 2008 | 08:41 PM
MrMT's Avatar
9th Gear
Hello,
Has anyone here replaced the ballast on the right side? Can you tell me how to do it? 2003 CL
Old Feb 7, 2008 | 09:55 PM
OscarCL3.2's Avatar
Go Gators
It's actually quite simple.
You need a slotted screw driver, phillips screw driver, 10mm socket, another socket slightly smaller than that (not sure of size...test for fit), and a tamper proof bit set
Removing Bumper (Tools = Solotted Screw Driver; Phillips Screw Driver; 10MM Socket)
1. Remove screw in front of each front tire (where bumper meets front quarter panel on each side). (Should be Phillips SD)
2. Remove plastic pins from the underside of bumper (4 of them). (Using Slotted SD)
3. Remove 10MM Bolts from underside of bumper. (2, one on each side)
4. Remove plastic clips on top of bumper. (8 or so)
5. Remove screws on top of bumper. (3 screws, using Phillips SD)
6. Unplug foglights. (for 01-02 models)
7. Remove bumper.
Removing Headlights
1. Remove Bumper
2. Remove bolts from the side of the headlight housing.
3. Remove two bolts under the headlight housings.
4. Unplug connections.
5. Remove two bolts from the top of the headlight housing.
5. Remove headlights.
Removal of Ballast
1. You have to use the tamper proof bit to open the housing to get to the xenon bulb. The screw is near the plug for the bulb's power.
2. Remove power connector from the bulb.
3. Remove the ballast from the lens/housing with a phillips screw driver.
To replace...just follow the steps in reverse order.
Old Feb 8, 2008 | 11:08 PM
MrMT's Avatar
9th Gear
Hey OscarCL3.2,
Thank you for all the info. I'm going to try and replace it this weekend. Thank you for all your help.
MrMT
Old Mar 20, 2011 | 01:04 PM
AARONSredTYPE-S's Avatar
i will doing this soon
Old Aug 21, 2011 | 09:17 PM
BlackClNova's Avatar
6th Gear
I had one ballast out so I but a d2r kit online and switched out both ballast and a relay harness to gain power directly from the battery. Will post posts asap.
Old Apr 2, 2012 | 06:29 PM
kux03's Avatar
5th Gear
I had one ballast out and decided to do a complete conversion. Check out this thread ---https://acurazine.com/forums/showthread.php?t=716617--- it was a lot of help when getting acquainted with everything.
The conversion kit I used was the one mentioned here- https://acurazine.com/forums/showthr...=788745&page=1
couldn't be happier, especially with the amount of money I saved.
Old May 10, 2017 | 11:59 AM
IHaveNoIdea2012's Avatar
Stay away from HIDExtra - there terrible.
Old Mar 19, 2020 | 03:10 PM
Robert Legette's Avatar
Are y'all talking about the headlights
forcemac101
Jul 3, 2012 11:56 PM
simran4h
Apr 3, 2011 10:34 AM
erick3
Feb 16, 2010 04:43 PM
rob-2
Mar 22, 2008 02:30 PM
Royal_Dragoon
Jun 28, 2006 04:48 PM
