Installing Front Right Headlight
Old Mar 22, 2008 | 02:16 PM
rob-2's Avatar
I also got a front headlight, are their instructions online that would walk me thru the swap?
It's an OEM Honda part.
Rob
Old Mar 22, 2008 | 02:26 PM
01tl4tl's Avatar
check the DIY section for Clearing or blacking headlights
look under the lower bumper for plugs and on the bumper ends for bolts
pop that bumper cover assembly off ( need friend for one side of it) off and there is the headlight assembly
NOTE disconnect battery before playing with headlights
transfer over all the parts, use latex or rubber gloves handling bulbs
use silicone seal where the wires go thru the bottem of housing to protect ballast.
Old Mar 22, 2008 | 02:30 PM
rob-2's Avatar
Thanks, also ran into this through google. I think it's too big a job for me to do by myself. Will either get a budy or bring it to a local shop.
THank you 01tl4tl for your help.
1. DISCONNECT ALL Wires leading to ur headlights. Take out the bulbs.
2. Remove the Corner Lights on the bottom portion of the bumper.
3. Remove the Grill
4. Remove the bumper itself. Its held on by i think 5 bolts.. 3 in the front, one on each side.. and 2 screws under the tirewell in the front... you need a phillips screwdriver to remove it.
5. Upon removal of the bumper, remove the metal reinforcement bar.
6. After removing the reinforcement bar, you'll see the 3 bolts on the bottom that are holding the headlights down. Remove those. Also remove the 2(?) bolts on the top of the light.
7. After removing the bolts, pull the headlights out. You might have to move it from side to side to get it out.. takes a couple mins
Feb 25, 2020 09:57 AM
HairyMonkey019
Apr 22, 2016 10:50 PM
JnC
Sep 11, 2015 06:06 AM
08 NBP TL
Sep 8, 2015 08:49 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
