Wires through Firewall
Old Oct 19, 2009 | 01:29 PM
gnuts's Avatar
3.5 psi
I need to run wires through the firewall into the engine bay. I did a search and saw that there is a plug or something behind the pedals, but the info was vague. I see a rubber circle i can pull out, but there is still metal behind it. What's the best way to do this? Thanks in advance.
Old Oct 19, 2009 | 02:12 PM
gnuts's Avatar
3.5 psi
I found the whole! I'm installing an alarm...trying to DIY!
Old Oct 19, 2009 | 03:17 PM
gnuts's Avatar
3.5 psi
can anyone tell me where i can locate the fuel pump and starter relay circuits? I need to splice into these under the hood. I have no manual and i'm lost under there. Pictures would be amazing.
Old Oct 19, 2009 | 05:37 PM
Rajca's Avatar
wham bam thank you ma'am
their a fuel pump fuse on the drivers side fuse box. check the fuse box thats under the hood. on the back side of the panel it will say what is what.
Old Oct 19, 2009 | 07:41 PM
Rajca's Avatar
i just drill a hole in the fire wall and put a grommet in the hole. its hard to find a good spot for a hole.
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
