window regulator!
Old Mar 27, 2011 | 05:16 PM
BIGBOOMER77's Avatar
Socal
window regulator!
i cant really find what im lookin for in the search. i knew there was a discount for azine on acuraoemparts or delray. i need to find a driver side window regulator for 03 cl-p. my shop wants to charge 250 for everything. is it an easy install? are the pulleys and everything already attached? i can find the part for 80 + shipping. just spent about 3k on a tranny/engine mount job and need to be budget minded
Old Mar 27, 2011 | 05:50 PM
friesm2000's Avatar
B A N N E D
yes everything comes as one, minus the motor itself, that has to be transferred over to the new regulator
and i am assuming the cable broke on yours also (actually the end of it held on by some plastic probably broke)
so you can hear the motor going, but you get no window movement
Old Mar 27, 2011 | 07:21 PM
civicdrivr's Avatar
The motor is included and installation takes maybe 30 minutes tops.
Old Mar 27, 2011 | 07:45 PM
SD02CL's Avatar
I concur....... there are about 7 or 8 bolts total. Unplug it, put the new one in, and bolt it back up....... if you make it down south I could help out if you want.
Old Mar 27, 2011 | 08:35 PM
friesm2000's Avatar
B A N N E D
i see too many regulators lol, but yeah even then they are normally only 3 bolts to transfer over though
Old Mar 28, 2011 | 10:24 AM
Socal
yea the cable/pulley broke. i cant remember right now and i might take you up on the help man. ill let you know
Old Mar 28, 2011 | 01:28 PM
friesm2000's Avatar
B A N N E D
yea it is quite common on cable driven regulators for the cable to break
Old Mar 28, 2011 | 01:37 PM
civicdrivr's Avatar
Especially one that has shitty reinforcements. The cable holder on the track is a bad design.
Old Mar 28, 2011 | 01:46 PM
friesm2000's Avatar
B A N N E D
kinda mention it before, but yes that is what breaks on most of them, the plastic eventually breaks, even if it is reenforced with metal
Old Mar 28, 2011 | 01:47 PM
civicdrivr's Avatar
It is reinforced by metal, but the tab is only on one side and easily bent after years of use, which is why the plastic ends up breaking.
Old Mar 29, 2011 | 04:03 PM
aznboi2424's Avatar
The plastic broke off of my regulator. Now I have an old motor from the old regulator since it still worked, I saved it. I just DIY the repair, it was easy.
le^2
Mar 17, 2026 05:06 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
AcuraKidd
Sep 25, 2015 11:18 PM
