Will Type-S gauge...
SOLD
Yes the gauges are interchangeable but I am pretty sure the rpm's will look a bit off since obviously you won't have the higher redline of a real CLs. That, and yes the cl does have TCS and not VSA, so the VSA light may be on since it can't read or interpret signals it usually would.
SOLD: 03 SSM CLS Auto
I ran with a CL-P gauge cluster for a day or two when I was testing out my LED conversion. The VSA/TCS lights never came on, and the temp gauge worked just fine. Although, every once and a while the temp would display a higher temp than normal, but then would show the correct temp after a while. And yes, the tach gauges are different, though they function the same way. If all you're wanting is the different gauge faces, I'd suggest just swapping out the gauge faces instead of the entire cluster, for obvious reasons.
thank you guys~ that really helped.
how do you swap just the gauge faces only then?
if you pull the needles, will that mess up the whole thing?
Originally Posted by Accord_V6_400m
Will it physically fit in my Accord dash?
CL-Pride
Originally Posted by gaping46and2
No need to pull the needles. Just push each gauge assembly out of the cluster and replace them.
SOLD
Originally Posted by ironsurfer129
Wow, it is that easy??? then maybe i should try doing it, and try to find a lower mileage odometer.
face and with the needles also eh?
i am definately gon try that.
thanks
Anyway, yes, the gauges will just pop out and plug into either CL-P/CL-S clusters.
CL-Pride
If you're going to be replacing the entire cluster with a lower mileage you'll have to report that to the DMV, then your vehicle may decrease in resale value because of it. Just something to think about.
What I mean is getting a lower mileage that is within the reasonable range since last smog check.
[QUOTE=Anyway, yes, the gauges will just pop out and plug into either CL-P/CL-S clusters.[/QUOTE]
sweet~ i will try that.
good to know.
good to know.
Originally Posted by distortedolskool
the 5 minute limit got me again. call and check but i believe this is what you are looking for.
78120-S3M-A13 SPEEDOMETER ASSY. 2003 CL 30.88 24.58
78125-S3M-A21 TACHOMETER ASSY. 2003 CL 36.38 28.96
78130-S3M-A21 METER ASSY., FUEL & TEMPERATURE 2003 CL 35.05 27.90
mrkingstonvi
02-22-2016 01:53 PM
DerrickW
11-15-2015 05:52 PM
