Will Type-S gauge...
Old Dec 12, 2007 | 10:18 PM
jjalpdda84's Avatar
do cl-s gauge fit cl-p??
what do and do not work?
any one done it?
let me know guys~ thx~
Old Dec 12, 2007 | 10:40 PM
VQPower37's Avatar
it should fit
Old Dec 13, 2007 | 12:16 AM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
any one done it?
Yes, it will work. Although there are several differences between the two, but either one will plug-n-play in the CL/TL.
Old Dec 13, 2007 | 01:28 PM
ironsurfer129's Avatar
CL-Pride
I thought the VSA light will comes up because CL-P doesnt have VSA instead a TCS
Old Dec 13, 2007 | 02:18 PM
artbran's Avatar
666 Speed
Also I think that the temp gauge gets messed up. When you start the car, it goes up to H and stays there...
Old Dec 13, 2007 | 03:12 PM
White92's Avatar
What about the 07-08 TL Type S Gauges?
Old Dec 13, 2007 | 03:19 PM
CL-Pride
^ That is for sure will not fit.
Old Dec 13, 2007 | 03:33 PM
NightRider's Avatar
SOLD
Yes the gauges are interchangeable but I am pretty sure the rpm's will look a bit off since obviously you won't have the higher redline of a real CLs. That, and yes the cl does have TCS and not VSA, so the VSA light may be on since it can't read or interpret signals it usually would.
Old Dec 13, 2007 | 04:08 PM
underst8's Avatar
140,000 miles young
Pull the VSA bulb to get around that one...and I think someone here figured out a fix for the temp gauge. try searching for that one
Old Dec 13, 2007 | 10:02 PM
I ran with a CL-P gauge cluster for a day or two when I was testing out my LED conversion. The VSA/TCS lights never came on, and the temp gauge worked just fine. Although, every once and a while the temp would display a higher temp than normal, but then would show the correct temp after a while. And yes, the tach gauges are different, though they function the same way. If all you're wanting is the different gauge faces, I'd suggest just swapping out the gauge faces instead of the entire cluster, for obvious reasons.
Old Dec 14, 2007 | 01:01 AM
jjalpdda84's Avatar
thank you guys~ that really helped.
how do you swap just the gauge faces only then?
if you pull the needles, will that mess up the whole thing?
Old Dec 14, 2007 | 02:28 AM
Accord_V6_400m's Avatar
4drs just wanna have fun!
Will it physically fit in my Accord dash?
Old Dec 15, 2007 | 01:01 AM
No need to pull the needles. Just push each gauge assembly out of the cluster and replace them.
Doubt it.
Old Dec 15, 2007 | 01:52 AM
CL-Pride
Wow, it is that easy??? then maybe i should try doing it, and try to find a lower mileage odometer.
Old Dec 15, 2007 | 02:49 AM
NightRider's Avatar
SOLD
Haha no I think that part stays in there...
Old Dec 15, 2007 | 11:32 AM
jjalpdda84's Avatar
oh~~~~~
face and with the needles also eh?
i am definately gon try that.
thanks
Old Dec 15, 2007 | 12:05 PM
distortedolskool's Avatar
gauges come out like so
Old Dec 16, 2007 | 01:10 AM
If you're going to be replacing the entire cluster with a lower mileage you'll have to report that to the DMV, then your vehicle may decrease in resale value because of it. Just something to think about.
Anyway, yes, the gauges will just pop out and plug into either CL-P/CL-S clusters.
Old Dec 16, 2007 | 02:14 AM
CL-Pride
What I mean is getting a lower mileage that is within the reasonable range since last smog check.
Old Dec 16, 2007 | 02:40 AM
Anyone else have any experience with this? Maybe someone can come down to Long Beach or we can meet up somewhere and give it a try.
Old Dec 16, 2007 | 02:49 AM
jjalpdda84's Avatar
[QUOTE=Anyway, yes, the gauges will just pop out and plug into either CL-P/CL-S clusters.[/QUOTE]
sweet~ i will try that.
good to know.
Old Dec 16, 2007 | 10:11 PM
evan03CL's Avatar
Wait...I just blacked out
Do you guys know where I could find just the gauge faces instead of the entire cluster?
Old Dec 16, 2007 | 10:17 PM
acuraoemparts.com carries them new. that would probably be your best chance at finding them.
Old Dec 16, 2007 | 10:24 PM
the 5 minute limit got me again. call and check but i believe this is what you are looking for.
78120-S3M-A13 SPEEDOMETER ASSY. 2003 CL 30.88 24.58
78125-S3M-A21 TACHOMETER ASSY. 2003 CL 36.38 28.96
78130-S3M-A21 METER ASSY., FUEL & TEMPERATURE 2003 CL 35.05 27.90
Old Dec 16, 2007 | 10:41 PM
You'd be better off purchasing a used cluster off ebay than spending ~$100 on just the gauge faces.
Jul 16, 2017 07:33 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
DerrickW
Nov 15, 2015 05:52 PM
