Why doesn't IceBox ingest water?
I've read that the Icebox won't suck in water the way other CAIs will. How far from the ground is the intake tube? What makes it different?
With the Icebox, the filter sits in a chamber that is about 6 to 8 inches above where a regular CAI will be. There is a tube leading down, but before water gets sucked in, that entire chamber has to be essentially flooded.
1 Post
Originally Posted by RaviNJCLs
The main difference is that with the regular CAI, the filter is at the end of a tube and is the only intake area for air. This is usually situated pretty low to the ground if your car is dropped.
Does the airbox containing the filter have any way for air to enter other than the inlet tube? Anyone know how far off the ground that inlet is in a stock 03?
YES… There is a small rubber “flap” in the side of the box that will open if the inlet tube is blocked by water.
It’s small, maybe 1” in diameter, but it should be enough to break the vacuum.
Former Sponsor
Originally Posted by Shawn S
I’ve helped install an Icebox in the past.
ALL SHOW AND NO GO
whats the diffrence between a stock air box with the baffle removed and a k and n drop in air filter and a comptech cold air intake ? besides being getto ? whats the hp and torqe diffrence and sound between the two and would the stock air box idea be a good idea ? by the way i already have a intake but im just wondering
The sound did change slightly, but again the Icebox is quiet anyway.
I've heard that the Bypass valve doesn't reall work all that well.
The problem is it actually works TOO GOOD.
I’ve tested mine with smoke (when I had it installed).
Whenever you “blip” the throttle it opens up and lets hot air from under the hood in.
I took mine off and put a piece of rubber in its place.
STL TL-S
09-23-2015 08:52 PM
