What's the lowest offset I can go?
Old Feb 1, 2004 | 05:35 PM
NiteQwill's Avatar
Adventurist.
As the topic says. I'm looking into 18" Rota Subzeros.
BTW.... go Patriots!!!!
Old Feb 1, 2004 | 05:45 PM
PiMpiN wHITe Cl-S's Avatar
+45 will be fine. that what i have.
Old Feb 1, 2004 | 07:01 PM
mcdanjw's Avatar
You can make +42 fit, but it's not fun.
It will involve either griding some of the front caliper off or using a spacer.
And don't foget rolling the fender wells in the rear.
I wouldn't do it again.
Old Feb 1, 2004 | 10:00 PM
GOT PSI?'s Avatar
It's Go-Time.
Like mcdanjw said, +42 with 18X7.5 will fit but you may need spacers to clear the calipers. See my sig. It worked for me.
Old Feb 1, 2004 | 10:46 PM
NiteQwill's Avatar
Adventurist.
Will a 45 or 42+ push the wheels out too much?
The euro look looks nice on euro cars, but on this Acura, I doubt it would...
Old Feb 2, 2004 | 07:05 AM
fuzzy02CLS's Avatar
+42 if you not lowered. If your lowered +43 will work(barly) Really should get +45 if your lowered. The less the offset, the more the wheel will stick out. I have 17X8 +50 lowered & have no problems.
Old Feb 2, 2004 | 07:22 AM
mcdanjw's Avatar
It doesn't stick out... it looks good. See the link below for pics. There are a couple looking down the side of the car so you can see how much a +42 sticks out. This is with an Eibach Prokit drop.
Old Feb 2, 2004 | 07:18 PM
GOT PSI?'s Avatar
It's Go-Time.
I agree, you should try and get +45 or higher offset. But +42 and lowered will work, but barely.
Old Feb 2, 2004 | 07:51 PM
ktgumbo's Avatar
Balla on a Budget
I have 42mm and I am lowered with CT springs! No rubbing here
Old Feb 3, 2004 | 07:08 PM
BBsAcuraRacing's Avatar
Strongly suggest 50 mm with a 17 x 8
Old Feb 3, 2004 | 11:09 PM
sgmotoring's Avatar
Bleed Honda Blue
I got 18x7.5 with +42 off set. I have Comptech springs and my don't rub or stick out of the fender. Some rims will not clear the caliper, especially those that have lips. It all depend on how the spokes on the rim are design.
Feb 25, 2020 09:57 AM
neuronbob
23
Jul 16, 2019 10:48 AM
SinCityTLX
55
Oct 11, 2015 01:20 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
bailey24
Aug 31, 2015 05:38 PM
