what do you use to clean engine?
Old Feb 22, 2005 | 09:53 PM
KPSBUDS420's Avatar
So what does everyone use to give the engine compartment a nice new look, mines is filthy right now and really needs to be clean. Will water and rag do, er do i need some chemical?
Old Feb 22, 2005 | 10:20 PM
JaredGMS's Avatar
Meat stick
simple green...good stuff
Old Feb 22, 2005 | 10:22 PM
NiteQwill's Avatar
Adventurist.
Simple green spray, let it set for a few minutes. Then a slow steady stream of water.
Be sure to cover the alternator and any exposed electrical parts with pastic.
Old Feb 22, 2005 | 11:26 PM
KPSBUDS420's Avatar
Simple green huh, the automotive or regular?, sorry but what else should i cover except the alternator?
Old Feb 22, 2005 | 11:39 PM
2ND_TIME_CLS's Avatar
I'm Back One MO' Gin
Gunk to clean,Eagle One for a lasting shine
Old Feb 22, 2005 | 11:41 PM
cltypeSLOW's Avatar
Don't Mess With Texas
use gunk to clean it....then rinse that off...of course remember to always cover electrical. then to make a real lasting shine. this may sound weird but it always works for me and lasts forever im talkin months. after the engine dries spray armor all tirefoam over the whole enginebay and then close the hood and drive it around for like 10 min. the heat bakes it into the plastic and such. it will last a lonnnggg time
Old Feb 23, 2005 | 06:56 AM
Red-CL's Avatar
Doin' da crack shuffle
A lot of detailers I know do that.
Looks good but it's a pain in da ass when you try to check something under the hood and get it all over you.
Old Feb 23, 2005 | 11:37 AM
RaviNJCLs's Avatar
Mine is still fairly clean, so when I wipe it down, I just used some simple green, and wipe it up with a moist sponge. I'm not a big fan of letting water in my engine bay. Then I just dry and put on some protectant on the plastic parts. Looks OK to me.
Old Feb 23, 2005 | 11:47 AM
fuzzy02CLS's Avatar
I use Greased Lightning. You can get it in most auto stores. And It works!
Old Feb 23, 2005 | 11:44 PM
ghost_masterCL's Avatar
what do you mean by "put plastic over the electronics"? like plastic baggies? or seran wrap?
and what electronics besides the alternator? ANY wires? that would be a lot of work., or just anything immediately visible? I would imagine it wouldn't be THAT bad to bot cover them up. I know there are some wires on the underbody that get sprayed with water all the time fromt eh rain.
we should obviously cover up the CAI filter too right?
Old Feb 24, 2005 | 02:57 PM
cltypeSLOW's Avatar
i usually just cover up the fuses and alternator....just really open looking stuff....
Old Feb 24, 2005 | 05:35 PM
Cruz_msl's Avatar
My Member is Registered
it's all designed to get wet, ya foos. Spray away and try not to get any on the paint.
Old Feb 24, 2005 | 09:01 PM
ou sig's Avatar
Boomer SOONER
yup, you dont need to cover anything other than a CAI filter, just dont hit it with high pressure and you are all good
Old Feb 24, 2005 | 10:31 PM
DRM600's Avatar
i spray simple green or some of that orange cleaner and let it sit for a few minutes. then everything is rinsed off real good. i then start the engine and let things heat up and get steamy while i clean the wheels or something. then i wipe everything down with a damp rag.
Old Feb 24, 2005 | 10:54 PM
CLSpeedfreak's Avatar
Need more pwr!
Engine Clean
Water
Try the high pressure sprayer at the car wash. Use the Tire Foam Silicone on the Engine Cover and Hoses to make them look new.
Old Feb 25, 2005 | 01:03 PM
dgracer's Avatar
I second the simple green but I then use a shop vac and blow everything dry including the alternator and electrical connections. I usually then treat the plastic and rubber parts as well. Havent tried the tire shine all over everything. interesting. I'd be afraid it would collect dust like crazy.
Old Feb 25, 2005 | 01:10 PM
mrsteve's Avatar
Dust, road debris, it collects everything. I wouldn't suggest using the tire stuff.
oyayjoe
Jan 1, 2019 10:17 PM
01CLOwner
Oct 9, 2015 01:07 PM
sockr1
Oct 1, 2015 01:31 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
Sep 14, 2015 10:09 PM
