what do you use to clean engine?
So what does everyone use to give the engine compartment a nice new look, mines is filthy right now and really needs to be clean. Will water and rag do, er do i need some chemical?
use gunk to clean it....then rinse that off...of course remember to always cover electrical. then to make a real lasting shine. this may sound weird but it always works for me and lasts forever im talkin months. after the engine dries spray armor all tirefoam over the whole enginebay and then close the hood and drive it around for like 10 min. the heat bakes it into the plastic and such. it will last a lonnnggg time
A lot of detailers I know do that.
Looks good but it's a pain in da ass when you try to check something under the hood and get it all over you.
Mine is still fairly clean, so when I wipe it down, I just used some simple green, and wipe it up with a moist sponge. I'm not a big fan of letting water in my engine bay. Then I just dry and put on some protectant on the plastic parts. Looks OK to me.
what do you mean by "put plastic over the electronics"? like plastic baggies? or seran wrap?
and what electronics besides the alternator? ANY wires? that would be a lot of work., or just anything immediately visible? I would imagine it wouldn't be THAT bad to bot cover them up. I know there are some wires on the underbody that get sprayed with water all the time fromt eh rain.
we should obviously cover up the CAI filter too right?
Originally Posted by Cruz_msl
it's all designed to get wet, ya foos. Spray away and try not to get any on the paint.
i spray simple green or some of that orange cleaner and let it sit for a few minutes. then everything is rinsed off real good. i then start the engine and let things heat up and get steamy while i clean the wheels or something. then i wipe everything down with a damp rag.
I second the simple green but I then use a shop vac and blow everything dry including the alternator and electrical connections. I usually then treat the plastic and rubber parts as well. Havent tried the tire shine all over everything. interesting. I'd be afraid it would collect dust like crazy.
sockr1
Oct 1, 2015 01:31 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
