Weird Noise
Advance
Weird Noise
Im not sure if this should belong in Problems & Fixes so i'll try here first. My CL is making a weird whine when accelerating, if I rev the engine at a dead stop in park/neutral it doesn't make the sound, but if I go to drive off it'll get higher pitched as the MPH goes up, than it evens off after a certain MPH. If I let off after it evens out it goes away, than if I get back on it it comes back. Im not flooring it or anything, just normal acceleration with shifts at like 3k. Could it be the whine of the torque converter spinning? Anyone else have this problem? Thanks
///M Power
hmmm...im having the same exact problem..when i accelerate it sounds like im supercharged, i honestly couldn't think of what it could be. i'd like to know also..
In the Mid-South meow
i had the same problem. this noise happens when using D1>D2. same whinding SC noise. also happens when i perform U turns. brought it to the dealer and they flushed out the power steering fluid and it's gone. maybe this will help you guys out there.
Advance
So flushing the power steering fluid made the whine go away? that's weird, the noise occurs whatever gear im in, regardless.
You flushed out the PS system and replaced the fluid with what type? I think im going to try this.
2003 CL-S 6SPD
Confirmed, its something to do with the powersteering fluid. I too started to hear this whine noise when i accelerated, but because of the colder weather and a recent oil change (changed to full synth) i didnt think much of it. Especially when it sounded neat, meaning it did sound like a turbo or supercharger. But after a few weeks i got this crazy loud noise coming from the front (made a thread). Anyways, after looking under the hood i noticed that my power steering fluid was low. I went and topped off the fluid (specialized honda/acura stuff) to the proper leves and all noises are now no longer. The loud noise is completely gone along with that turbo supercharge whine noise. So i suggest you either make sure the fluid is at its full line along with it being clean. Just make sure you use Honda/Acura certified stuff.
the 2 sounds can happen : power steering or auto tranny
sometimes when i replace auto trannies on TL or CL, it never makes the same sound : some trannies are dead silent, some make a little whine and some are louder.
if it gets too loud, you should be able to have it replaced.
twice i had to replace trannies just after installing them because they were not rebuilt properly.
but you guys are talking about 2 different sounds in this thread
2003 CL-S 6SPD
Possibly... im just confirming my findings from the other day with the other guys who had the same problem. The initial poster could be a different situation, but it was nearly identicle to me and the others suggestions. Hope things work out.
Advance
Hmmm.. kind of weird, I checked my power steering fluid level and it's filled up to the max line. Doesn't look dirty either, this CL was just bought at a dealership so maybe they topped it off? Im not sure how to proceed, I don't want to waste money on a flush either.
I also here the same whine when I accelerate as well. Another thing I noticed was that when I turn a corner at low speeds i here rubbing type of noise. Can that be the cv joints going bad or needing to be repacked? Does anyone experience the same problem. My cl-s is stock height with stock tires.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
