VTEC Problems Help!!
Old Nov 22, 2003 | 04:06 AM
withoutcomp1's Avatar
Hey guys , i seem to be having a a little problem, once in a while when the car goes into vtech it will get stuck and hesitate , it makes almost the same sound as when you hit the rev limiter, it will stay doing that until i let of the gas and try again, then it may do it again or not, what do you think it is the actuator? anyone know how much one can be? or something else? HELP ME!! this sucks when i need to speed!!
Old Nov 22, 2003 | 09:22 AM
typeR's Avatar
if your oil pressure is low ,as in low oil level vtec will not engage,and instead you will have the ecu enter the fuel cut/rev limit
Old Nov 22, 2003 | 09:52 AM
No, it's not that, i just went outside and checked the oil, it is on the second dot. any other ideas?
Old Nov 22, 2003 | 09:57 AM
CL FWD SPEED's Avatar
What to do, what to think
could be a defected by-pass valve actuator
Old Nov 22, 2003 | 10:21 AM
2001CL's Avatar
Ricky: Drugs > Football
recet the ecu???
Old Nov 22, 2003 | 10:42 AM
CLS2001_97124's Avatar
Revving at 9K...
Never happen to my CLS before, but I know on my S2000, if the car is not up to certain temperture, it will not Vtec.
Old Nov 22, 2003 | 11:22 AM
It doesn't happen al the time, and when it does happen it does it whenever hot cold ect.
Old Nov 22, 2003 | 11:53 AM
BIGPOPPA21's Avatar
Death Metal
could it have something to do with the v-afc
Old Nov 22, 2003 | 11:55 AM
i don't think so, i never had this problem before
Old Nov 22, 2003 | 01:58 PM
scalbert's Avatar
If you have a VAFC it could be acting up. It could also be a defective VTEC oil pressure switch. If you checked the oil level and it is fine then you may need to look at the oil pressure.
Of those three things I would say the VAFC is the most likely culprit and the easiest one to test by bypassing it.
Old Nov 22, 2003 | 03:23 PM
rondog's Avatar
Former Sponsor
faulty bypass valve is really gonna let you go into vtec, but with no extra power, kinda like a cl-p. but what you have sounds like what I had in heavy rain once, the car makes a crazy noise and boggs. any lights go off? check your CAI connection. Maybe your throttle cable is loose?
IBankMouse
Jun 13, 2020 12:53 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
