vsa, tcs, abs lights
Old Mar 9, 2010 | 10:59 PM
bang47's Avatar
hey guys, my vsa, tcs, and abs lights are all on at the same time, is this bad???
Old Mar 9, 2010 | 11:05 PM
pits200's Avatar
Need more info than that. A couple things can cause that to happen.. What else was going on with the car?
Old Mar 9, 2010 | 11:16 PM
MrFluffy's Avatar
To many cars in my garage
X2
somethings wrong if thats what you mean by "is this bad"
Old Mar 9, 2010 | 11:30 PM
bang47's Avatar
i replaced my front rotors and brake pads, but the car still shakes when i brake, the motor runs fine, all three lights are on at the same time when I'm driving.
Old Mar 9, 2010 | 11:31 PM
bang47's Avatar
what do u think is wrong with it?
Old Mar 9, 2010 | 11:51 PM
MrFluffy's Avatar
Its hard to say with out scanning the codes
Old Mar 10, 2010 | 08:16 AM
SlickShiftNall6's Avatar
Quarantuning
Isn't this what happens right before the Transmission is about to go?
Do you have any rough shifting, or any of the other symptoms of the infamous glass Trans?
I remember reading on here that when all three lights come on the Trans is about to go boom! Thanks god I got 6 gears...
Old Mar 10, 2010 | 09:33 AM
pits200's Avatar
If this just happened when you replaced your rotors, Im guessing it might be a speed sensor which is located on each wheel. Its a little black oval shaped thing which is located near the axle teeth and it picks up the turning of the axle.
Now the sensor is somewhat near where you would be working on your car when you change the rotors.
Unless it is just a coincidence that it might be your tranny, this would be my best guess as to what it is based on the information you gave.
Old Mar 10, 2010 | 01:59 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Dude scan the codes..
If the car feels fine and does not shake then its not a coil pack.
Mine came on all three times my tranny went and the car felt fine untill 2-3 days later tranny went BOOM... $3000 GONE!!
Old Mar 11, 2010 | 02:12 AM
acura_dipset_tl's Avatar
AM To WDP In My Garage
Anybody have a diagram of where the front speed sensors are located? Because the check engine light came on and I was told that one of the speed sensors needs to be replaced (driver front side).
Thanx in advance
Old Mar 11, 2010 | 05:59 PM
tangsauce's Avatar
Located on the knuckle beside the lower ball joint. Wires run up along the side and up into the engine bay. Open your hood and you'll see two orange connectors by your struts.
Old Mar 12, 2010 | 01:08 AM
Thanx alot, now all I have to do is find the part numbers.
Old Mar 12, 2010 | 01:06 PM
tangsauce's Avatar
57450-S0K-A52 SENSOR ASSY., R. FR.
57455-S84-A52 SENSOR ASSY., L. FR.
For future reference all part numbers can be found @ acuraoemparts . com
Old Mar 13, 2010 | 03:04 PM
thanx again, you guys are awsome.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
