vsa, tcs, abs lights
Quarantuning
Isn't this what happens right before the Transmission is about to go?
Do you have any rough shifting, or any of the other symptoms of the infamous glass Trans?
I remember reading on here that when all three lights come on the Trans is about to go boom! Thanks god I got 6 gears...
If this just happened when you replaced your rotors, Im guessing it might be a speed sensor which is located on each wheel. Its a little black oval shaped thing which is located near the axle teeth and it picks up the turning of the axle.
Now the sensor is somewhat near where you would be working on your car when you change the rotors.
Unless it is just a coincidence that it might be your tranny, this would be my best guess as to what it is based on the information you gave.
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Dude scan the codes..
If the car feels fine and does not shake then its not a coil pack.
Mine came on all three times my tranny went and the car felt fine untill 2-3 days later tranny went BOOM... $3000 GONE!!
Located on the knuckle beside the lower ball joint. Wires run up along the side and up into the engine bay. Open your hood and you'll see two orange connectors by your struts.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
