Vibration at 75mph.
Old Mar 19, 2004 | 11:24 AM
jriga's Avatar
Vibration at 75mph.
At 75mph on the freeway when I push the brakes I get some serious shaking in the steering wheel, seat, etc...
I thought it was warped front rotors - so I had them turned yesterday... didn't help the problem at all...
Has anyone else experienced this and what was the fix??
I guess I could have the rear rotors turned as well, but it doesn't seem they would cause this vibration?
Old Mar 19, 2004 | 11:25 AM
lou_RENAMED's Avatar
its the abs bro and also did you balance the wheels and stuff..take all those measures before you spend more money unnecessarily
tmk70's Avatar
Masshole
Sounds like they didn't fix it right the first time. Still sounds like warped rotors to me.
Old Mar 19, 2004 | 11:29 AM
G-UNIT's Avatar
Poppin them thangs
is it possible for pads to be warped?
also, are they aftermarket rims/tires? it could be the wheel is not on the center of the hub...meaning u need hub rings....
I need hubrings for vibration on speeds above 150 km/h, roughly 95 mph....
Old Mar 19, 2004 | 11:35 AM
yep another warped rotor syndrome...park it on the side till he picks it up...and next time it wont be COURTESY...we'll charge his dumbass and then we'll fix it
Old Mar 19, 2004 | 11:41 AM
GreenMonster's Avatar
Originally posted by lou
its the abs bro
I had the abs kick in once when I was doing some heavy braking coming off the highway. ABS kicked in, and I thought for a moment that the rotors were warped. Haven't felt the vibration since, so I think my rotors are still ok.
Sounds like you might have warped rotors or the something is wrong with the tires (cupping?? balance??). I had a bubble in my drivers front tire, and I got a slight vibration at certain speeds. Swapped out the bubbled tire for a used oem, and it rides nice again.
Old Mar 20, 2004 | 09:56 AM
jriga's Avatar
It's frustrating as hell - the car has 51,774 miles on it - just out of warranty. Trying to see if Acura will do something about it - I already paid to have the rotors turned at my store, only $50 but still...
It's bad on the freeway, not so noticeable at lower speeds.
The turning of the front rotors actually seems to make the problem worse - very strange...
jriga's Avatar
PS - Wheels are balanced.
Old Mar 20, 2004 | 10:42 AM
jriga's Avatar
Acura of Columbus will not perform the service bulletin as goodwill since I didn't buy the car from them - they gave me Acura's 800 number, they're closed.
Not impressed at ALL with Acura service so far. They wanted $536 to replace the front/rear pads rotors. WTF?!?!
I can put PowerSlot rotors on and Greenstuff pads for less than that...
Maybe I should have bought a G35C after all.
Old Mar 22, 2004 | 01:55 PM
jriga's Avatar
Just as a followup, Acura of Columbus went ahead and replaced all 4 rotors, and pads too...
Hope that solves the problem - if not, Powerslot will have an order from me. That vibe sucks... makes my smooth CL-S feel like an older Infiniti I30... the brakes on those were risky.
:P
J
Old Mar 23, 2004 | 11:45 AM
gurot1's Avatar
I had the same problem. I had the rotors machined at around 1500km, but around 15000km there was vibration again while braking at higher speeds (ie above 100km/hr sometimes even less!). Took it back in and this time they turned the rotors again and replaced the pads (which they should've done in the first place) and now the car brakes nice and smooth even when it's going 185km/hr...I just had to test out how fast 4th gear would take me! I think it was my front rotors that were messed up.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
