V1 hardwire problem, unit reboots with ignition
Old Mar 13, 2004 | 01:58 PM
Nitin's Avatar
But I just got here
The V1 turns on when I turn the key to the "On" position, but then the unit reboots when I start the car up. Is that normal? I usually leave the key in the "On" position for a few seconds so that the gauges adjust, then I start the car up. I already searched and didn't find this discussed at all.
Old Mar 13, 2004 | 02:04 PM
Linner's Avatar
yes it is, good example is when you leave your headlights and unlock the car, when u start the car up the headlights flicker instead of staying on, showing the re-igintion of the battery or whatever u call it.
Old Mar 13, 2004 | 02:58 PM
NOVAwhiteTypeS's Avatar
normal operations prob due to change of voltage
Old Mar 13, 2004 | 07:16 PM
moonraker's Avatar
goldeneye style
yup this is normal
Old Mar 13, 2004 | 08:50 PM
Nitin's Avatar
But I just got here
Thanks for the responses guys. I guess I'll just have to live with it then. Oh well.
Old Mar 13, 2004 | 10:46 PM
withoutcomp1's Avatar
Where did you get power from? if you got it from an acc line (radio heat /ac ) it will do that, if you want to resolve that problem take down the driver sid dash under the steering wheel wheel and find the harness that goes to the key cylinder cut the loom off of it it and tap the power from your v1 hardwire kit to the 12awg black with a yellow tracer. Problem Solved!
Old Mar 14, 2004 | 01:11 PM
blader's Avatar
Audi S4 driver
Or, go to the backside of your fusebox (side facing your pedals). there are 4 male outputs. Two are for power regardless of whether the car is on or off, and two are for switched power (only when ignition is on). This is where I have my V1 and it doesn't do that.
Old Mar 14, 2004 | 05:09 PM
2001CL's Avatar
Ricky: Drugs > Football
can you hardwire it from the lamp on top, by the sunglas holder? You seem to get better range with it up higher.
Old Mar 14, 2004 | 05:48 PM
yeah but there is only constant power up there
Old Mar 14, 2004 | 09:09 PM
`ill*tl's Avatar
I have my V1 hardwired to Fuse 30A (Windshield wipers) and I don't get that problem.
Old Mar 14, 2004 | 09:59 PM
i hardwired my old esort 8500 to the fuse for the heated side mirrors. it only turned on w/ the ignition
Feb 25, 2020 09:57 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Soul_Deamon
Sep 7, 2015 04:25 PM
yahelou
Sep 6, 2015 09:12 PM
