UR pulley install questions
Just ordered my SSc kit from josh, and had a few general questions. For the crank pulley, what is the best way to get the bolt out on a 6 speed? Also, is the PS pump reverse thread? What aboout the alternator? Any tips greatly appreciated
get a 19mm socket on it, put a breaker bar on that, and a cheater on the breaker bar. wedge it either on the ground or onto a suspension piece, and crank your car for 0.1 sec. make sure you pull the ignition fuses or use the valet. should be simple
Originally Posted by fsttyms1
As do i.
Unless you have the tool this is the easiest method.
Former Sponsor
Originally Posted by Silvaccordex01
Thanks guys for the tips on the crank pulley. What about PS pulley and alternator? Are either of those reverse thread?
anything else just ask again.. i spent a LONG time doing the install, because it was cold, i was getting dirt dripped on me a lot, and even though everyone says it's easy, there's no exact instructions.. but if you are mechanically inclined, you'll figure it out. not much to break around there, either.
Man that friggin crank pulley just will not budge. Im kinda scared to try the crank the engine with the breaker bar wedged idea. Where exactly am i supposed to wedge a breaker bar? any other way to do this? Also, am i supposed to loosen the crank pulley with the belts on or off? And how do i keep the pulley from spinning other than having someone press on the brakes?
Ok finally got that crank pulley off and the new ones installed. Man what a bitch. Used the suggestion of the breaker bar and it came off. Did not sound pretty though and car back fired. So hopefully nothing got fucked up. Now, my problem lies with the alternator pulley. It absolutly will not come off. Im holding the old one with some plies and the nut seems like its spinning but its not coming off. Is there a trick to this im unaware of?
Yes very, and i had no belts or alternator in or side mount. Like i said didnt sound pretty and im worried about my car now. The Crank pulley is on, the Ps pulley is on. Its all ready to be put back togeather besides the alternator. evidentally according to the manual you need 2 wrenches to get the alternator pulley off. Shitty because i dont have a 22mm wrench, which means i have to wait until tomorrow to put my car back togeather. Damnit
wow im done. What a pita! I gotta find a place that can torque my crank pulley bolt tho cuz my torque wrench only goes to about 130, and i dont have the honda tool to hold the pulley in place. Now for my P2R plenums later today!
Skirmich
Sep 15, 2015 06:41 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
