update on chip!!
Old Jun 21, 2003 | 02:02 AM
  #41
Ant7701's Avatar
Sweet as Gold
Now I'm confused...the unichip and the chip from allen are two different chips???What is the basic differences???Are either available right now???And also what is the difference between these and the Apex-i VAFC...cause you can change the air/fuel w/ that if I'm not mistaken???Can someone please break this down for me to understand better and also for us second gen's...our ecu's contain the codes for our keys and immobilizer system...if we replace our ecu's...how will they reprogram the new ecu to our keys w/ no hassel or a Honda PGM tester???
Old Jun 21, 2003 | 05:14 AM
  #42
types1967's Avatar
will everyone just be patient opak racing is doing this for us when everyone else let us down.again i spent a long time trying to get us this mod!!!! i dont want anyone to be negative just wait till it comes out and we will worry about the price when i discuss this with allen.
Old Jun 21, 2003 | 05:31 AM
  #43
kHmER Co's Avatar
mister D
have they found a test car yet
Old Jun 21, 2003 | 06:02 AM
  #44
types1967's Avatar
still looking for test car
Old Jun 21, 2003 | 07:06 AM
  #45
typeR's Avatar
Originally posted by Juker008
[B]I just spoke with Allen. My only questions were about the programability. He stated that it would need to be sent back to them for reprograming. But I told him that I and
others (Type-R, Scalbert, AM2K) would be capable and very appriciative to be able to do the programs themselves.
apperantly i have you fooled ericL 's name should be up there not mine...i barley understand what those guys are saying let alone have the capability of doing
Old Jun 21, 2003 | 09:09 AM
  #46
ModAddict's Avatar
It's all good Eric.
Old Jun 21, 2003 | 09:23 AM
  #47
scalbert's Avatar
From what I can tell in the original post, Allen is working on a program for the UniChip for the CL:
ok guys heres the lowdown.opak racing in california is making the piggyback unichip for our cars.their
With this being the case the term chip ended up being incorrectly used and should be disregarded.
The UniChip is significantly different from a VAFC as it ends up controlling the injectors and the ignition coils. The VAFC just alters the MAP signal to the ECU which has limited capability in fuel control. But since the UniChip intercepts and alters the signals to each injector and coil the capability is greatly expanded. Plus, the UniChip has a prgrammable map which allows you to tune over a wide ranges of engine load.
Old Jun 21, 2003 | 10:00 AM
  #48
ch1276's Avatar
great job eric
Old Jun 21, 2003 | 10:16 AM
  #49
NSX-Tuner's Avatar
boosted is best
I spoke with Allen at Opak Racing - (707)935-3999/(707) 584-9300 about installing the UNICHIP on my CLS 6 speed with CT intake/headers/b-pipe/exhaust and he told me the following:
  • They are working on the CL and other Acura model maps.
  • In order to come up with various ECU rempappings for the CLS, they need to start with a fully stock CLS (or a fully modded car temporarily put back to stock) to do the initial optimized map for a stock CLS.
  • Using the same stock CLS, add back in one mod at a time to create a new map for each mod.
  • Ultimately, the end result would be maps for various mod configurations for our CLs.
  • Allen told me that the guinne pig would get the UNICHIP fully installed, mapped and dyno'd only for their cost for the UNICHIP hardware.
  • Each type of mod (intake/headers/cat-back/axle-back) changes the engine's flow characteristics and usually adds peaky performance gains are higher RPMs while causing power losses at lower RPMs. By remapping the timing and A/F values for the engine, those peaky gains and low-end losses can be flattened out to provide more low-end power and a flatter power curve.
I have CT intake/headers on my CLS 6sp and only live about 1 1/2 hours away from Opak Racing, but I've already sold my stock intake and headers. Otherwise, I'd do it.
Here's what I understand about the UNICHIP. It's not a computer chip as some have inferred, it's a fully programmable computer that's connected between the ECU and the engine. It stores the ECU map offsets values for timing and F/A for various RPMs and load conditions. All it does is add its mapped offset values (+/- 1, 2, 3, etc...) to the ECU's mapped values. It does not reprogram the factory ECU map but stores the mapped offset values itself. So if you disconnect it, car goes back to stock.
I think $700 is very reasonable for at least a 10% WHP gain (25-35 WHP depending on what mods are installed) considering some people pay $4-5k for a SC and only get about 54WHP gain.
One other thing, even after there are maps available for our cars, each car is different enough (stock vs. stock) that you can have a custom map done for your car to get additional gains for an additional $200.
Old Jun 21, 2003 | 10:40 AM
  #50
scalbert's Avatar
You want to borrow my stock pieces for this. I have everything which was only on the car for less than 1000 miles.
Old Jun 21, 2003 | 11:01 AM
  #51
NSX-Tuner's Avatar
boosted is best
If you are serious, I might take you up on that. I have a 2003 CL Type-S 6 speed. However, I've been told there are some slight differences between the auto and 6 speed parts. Not quite sure what, but that's what Acura says cause some P/Ns are different. To keep things simple, I'd only consider using 2003 CL Type-S 6 speed stock intake and headers. The other problem is you appear to be located in Woodstock, GA. Not sure I want to deal with shipping parts both ways. Would get a little expensive. Unless... Allen would also give you a deal for participating.
Anyway, I need to get the CT exhaust and b-pipe (if available) installed next month before I consider the UNICHIP. I might just have them do a custom mapping on my car and not bother becoming a guinne pig.
Old Jun 21, 2003 | 11:10 AM
  #52
ModAddict's Avatar
With this set up we should be able to move the vtec and rev limit, add larger injectors, lower the fuel pressure to the point that the stock regulator will do the job instead of running the higher fuel pressures with the FMU, and then run the boost up to the point the blower looses eficiency,....10 psi, maybe.
Old Jun 21, 2003 | 11:50 AM
  #53
allmotor_2000's Avatar
If So Cal is a little closer to you... I offer all my stock parts as well (unfortunately this only amounts to the Header and air-box).
Old Jun 21, 2003 | 12:08 PM
  #54
TypeS_boi's Avatar
CL-S retired 10.17.06
this doesn't pose any warranty issues does it? I told eric I wouldn't mind letting my car go for a day or 2. I am all stock 5AT. Does this mean they then would need a modded 5AT to do the map for each mod? What about a 6spd? Aren't they going to need a 6spd test vehicle too? I'll call them on monday and see what's up.
Old Jun 21, 2003 | 12:15 PM
  #55
Smitty's Avatar
Yeah do it Cls6sp03... I was going to go the same route as Steve and Allmotor, but I am over on the east coast..
Someone has to step up here and follow through or this will be 6 more months till we see the end result...
Old Jun 21, 2003 | 12:38 PM
  #56
JakeCL's Avatar
well i checked mapquest and they are 2 hrs from me, im stock six speed exept for axle back exhaust, how long do they need the car for?
Old Jun 21, 2003 | 12:45 PM
  #57
typeR's Avatar
wouldnt H/I be a better test car as most people that would buy this chip would be modded already
Old Jun 21, 2003 | 12:55 PM
  #58
Zapata's Avatar
Cost Drivers!!!!
exciting stuff!!!! i'll take 15% MORE POWER
Old Jun 21, 2003 | 01:41 PM
  #59
scalbert's Avatar
Well, we are in luck as I own an '03 6-Speed.
For me the shipping is not an issue. I just ship it on my company's UPS account.
Old Jun 21, 2003 | 01:59 PM
  #60
types1967's Avatar
im really happy that you guys want to participate in this.this is what i mean when everyone comes together and truely makes an effort together.this is what the board should always be like and we would never have any problems.were just one big family no matter who has what mod and so on.scalbert thanx for offering your stock parts and cls 6speed thank you for thinking about donating your car for us.i would be there in a heartbeat if i didnt live in nj.
Old Jun 21, 2003 | 02:56 PM
  #61
2001SC's Avatar
7th Gear
Thanks again to Types1967 for initiating this. I spoke with Allen this morning and volunteered my 5-sp auto (S/C, headers, exhaust) as soon as he is ready for it (about a month from now)
Old Jun 21, 2003 | 03:02 PM
  #62
sidemarker's Avatar
so will this work for the autos?
how will it affect the warranty?
so there will be different piggy back computers or will there be one specifically for i/h/e?
sidemarker
Old Jun 21, 2003 | 04:21 PM
  #63
types1967's Avatar
thanx 2001 sc for volunteering your car!! ok after the unichip is done i have something else im working on.im in talks with a few companies to design an intake manifold for our cars,if it works out it could be very good.
Old Jun 21, 2003 | 04:48 PM
  #64
types1967's Avatar
i just love modding!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!! i see a 12sec acura in the future
Old Jun 21, 2003 | 09:46 PM
  #65
ModAddict's Avatar
Now you really have my attention!
Old Jun 22, 2003 | 12:21 AM
  #66
maevonee's Avatar
man i really hope this comes through i cant wait~!
Old Jun 22, 2003 | 08:37 AM
  #67
types1967's Avatar
dont worry this will come true
Old Jun 22, 2003 | 10:18 AM
  #68
ferizzo's Avatar
still a Masshole
Thanks to everyone pushing and volunteering! I agree with Type R that someone needs to also get them an auto with H/I. I'd offer my TLS if it were somewhere in the NE area.
Old Jun 22, 2003 | 10:27 AM
  #69
Juker008's Avatar
TRELOS
HAAA, then I guess ur gonna have to take a trip down to S.WPB whenever ur feeling like alittle more hp .
Juker008
Old Jun 22, 2003 | 10:32 AM
  #70
Juker008's Avatar
TRELOS
If so u gonna finially bring ur car to me so I can throw on a wet shot and retard ur timing ?
Juker008
Old Jun 22, 2003 | 12:08 PM
  #71
Davediego's Avatar
4dr & I like it that way
i wish someone could get a TL-P or a CL-P in there
Old Jun 22, 2003 | 08:26 PM
  #72
Bulldog01's Avatar
Masshole
Dammit! I want 13s, and my H/I would be the perfect guinea pig.
Old Jun 23, 2003 | 10:56 AM
  #73
mc222's Avatar
I hate the Mets
So - Which one of you CA boys are gonna step up?
Old Jun 23, 2003 | 11:32 AM
  #74
MtBikR's Avatar
Sweet! and it Auto too huh? This should help as I am sure that S/Ced people will all be getting this and it is nice to know that our chances of getting customized maps for the blower are a close reality, Thanks!
Old Jun 23, 2003 | 11:50 AM
  #75
mc222's Avatar
I hate the Mets
Anyone have a CAI they could lend 2001SC?
Old Jun 23, 2003 | 12:00 PM
  #76
CCType-S's Avatar
The anti-misshift
Can't wait to see the result. Good job
Old Jun 23, 2003 | 12:11 PM
  #77
TranceFusion's Avatar
yes!..... more power for our cars!
Old Jun 23, 2003 | 10:11 PM
  #78
2001SC's Avatar
7th Gear
No need. The S/C comes with the Comptech Ice Box.
Old Jun 25, 2003 | 03:12 AM
  #79
kosb11's Avatar
7th Gear
Hey I would be willing to be a test dummy!!! I'm in Sacramento and I have stock parts in my garage. Let me know...
Old Jun 25, 2003 | 03:42 AM
  #80
NSX-Tuner's Avatar
boosted is best
types1967, I hope you don't mind if I help this effort along...
I've got some additional info:
I spoke with Jack at The Racers Group, the distributor of UNICHIP. UNICHIP is a piece of hardware that's been around for about 10 years and is made in I believe S. Africa. I also spoke with Allen at Opak Racing who is working for Jack to develop the maps for the Acura and Honda models, include the CL.
Allen said there are several phases to this development.[list=1][*]Start with one car only that has some mods but can be downgraded to full stock. He will need the car for as much as 3 days to put in UNICHIP, temporary wiring and remap car with different setups; fully stock and with different mods. A prototype wiring harness will be modeled from the temporary harness. When car is handed back over to who ever the guinne pigs is, the car needs to be returned after 250 miles to verify that everything is working correctly. After a week or so, the temporary wiring harness will be replaced with a newly manufactured harness.
So this is what you will get for donating your car and several hundred dollars for the cost of some hardware:
*Dyno Charts, stock vs. modded
*Full installation
*Custom remapping
*And the bragging rights
[*]Next, will probably need two more or more cars to further develop and verify maps and hardware and to prepare for CARB certification.[/list=1]
I've decided to wait until my car has all the CT goodies (intake,headers,b-pipe,exhaust) and only do the mapping for my configuration. I don't really want to put it back to stock. So I'm hoping to be a second round guinne pig.
