UniChip Possibilities
#163
Lead Footed
Originally posted by jet-tek
NA & interested!
NA & interested!
Especially since I'm loosing interest in the UR pullies.
Ruf
#164
Originally posted by CLS2001_97124
Steve, have you had a chance to talk with the Uni-Chip guys again since you made your decision?
#165
Bagged hybrid
For >$500, I would rather have an unit that I can change settings any time for future mods and maybe multiple profiles. After Steve gets the ECU harness made for both 6sp & 5at, I'm giving the e-manage a try on N/A.
#166
Revving at 9K...
I guess if all of us have the proper knowledge to "tune" a car, e-manage would be the answer, but since I don't, I need to consider the cost involved to get it tuned by others.
Btw, the UniChip can also store multiple maps, and it could be changed on the fly with a switch.
I think I will go ahead with letting them have the car if they still want to persue this development. Since I don't think as of now, according to Steve, the e-manage will not help the N/A cars much.
#167
Bagged hybrid
Can the UniChip advance the timing? I know a lot of time is going to be spent tuning with the e-manage, but I think it's going to be fun ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Good luck with the UniChip!
#168
This is all conceptual at this point but based on some solid data. But for the NA CL-S, both the e-Manage and Unichip will be able to control and tune the fuel curve as needed. In fact, they will both do this primarily through the same method.
The difference comes with ignition timing; the Unichip should be able to advance the timing.
#169
#170
Revving at 9K...
The guys at UniChip told me that the chip will have no problem of either raising or just flat out eliminate the rev limiter. Same with changing the Vtec change over point.
#171
Yes, I forgot to mention the VTEC engagement point; both will be able to control this.
As for the rev limiter, again conceptually, only the Unichip would have this abillity.
#175
Originally posted by 99%StockAV6
This link below has info for the non-6speed connectors. All but connector E.
http://www.v6performance.net/forums/...?threadid=4069
I think these are the part numbers for the 6speed.
1318612-1 125 Pin Connector Housing
353027-1 17 Pin Connector
353028-1 22 Pin Connector
353029-1 24 Pin Connector
353826-1 31 Pin Connector (it looks like you need two of these)
125 Pin Connector Housing 1318612-1
31 Pin "A" Connector 1318682-6
24 Pin "B" Connector 353029-1
22 Pin "C" Connector 353028-1
17 Pin "D" Connector 353027-1
31 Pin "E" Connector 353826-1
#176
Opps, I was missing one of the part numbers...
Actually and to keep it simpler, we would just need one 31P "A" and the 24P "B" connector; all wires associated with this install are on one of those two. The remainder could stay plugged into the ECU. I would use the housing but maybe cut off the end I don't need to reduce size.
#178
How is the UniChip different in the way it controls/monitors ignition timing compared to the e-manage?
#179
Bagged hybrid
I may be completed off base here, but it seems that we can potientally use the data collected from the UniChip (since it reads the CPS) and then use it on the e-manage to adjust the timing?
#180
Originally posted by typeR
great 500 it is !
great 500 it is !
#182
Sweet as Gold
Interested NA member here...w/ the Uni-chip timing and fuel curve is adjustable...I know that...however can we our selves adjust and tune or do we have to purchase another software map. What we basically need is timing control and fuel control w/ V-tech and revlimited control as well...but something that WE can play w/ at the track or tune ourselves.
#183
Revving at 9K...
btw, I just dropped off my car, and I was suppose to hear back by Wednesday night.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
I will keep everyone posted.
#185
awesome news Brian.
#186
Do you have the Helms manaul?? If so, can you scan the pages for the ECU connectors?? I need to compare this to the 5AT CL-S just to be sure they are the same.
#187
Originally posted by ModAddict
Are you looking for "PCM Inputs and Outputs At Connector A, B, C, & D"? It shows a line drawing of the connector at the top of the page, and the description for each terminal below it.
#189
#190
Lead Footed
Man you guys need to have your own show on the Speed channel or that new guys channel that has Hot Rod TV on it. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
I'd watch you guys mod our cars.![Boink](https://acurazine.com/forums/images/smilies/boink.gif)
Ruf
Ruf
#191
I got the drawings from Brad and the TL-S has the same pin outs and connectors as the CL-S5AT for the needed connections. Now I just need to do new drawings and source these too.
#195
BTW, below are the schematics for the harness. It is incomplete as I am unsure who will wire this to the e-Manage harnesses.
24P
31P
24P
31P
#196
So the e-manage harnesses are at the bottom of both diagrams,.... the top diagram would be for the injector harness and the bottom one for the ignition harness.
#197
Not really, leads from the 24P ECU harness will have connections on the base e-Manage, the injection and ignition harnesses. The 31P ECU connector will only hook up to the remaining lines on the base e-Manage harness.
We will most likely be able to get the harness already connected to eliminate any potential error.
#200
That was quick!
So if need be,....9 wires would be cut, and 9 could be tapped.
BTW,....this Helms is great!
I told my wife I could do anything now! She jumped for joy, and said yippeeee,.......
yea right!
yea right!
![Punch](https://acurazine.com/forums/images/smilies/punch.gif)
![Teef](https://acurazine.com/forums/images/smilies/teef.gif)
