turn signal bulb installation
Old May 23, 2003 | 03:47 PM
hipatknight's Avatar
how do i install new turn signal bulbs in a 2001 Acura Cl? do i have to take out the entire headlight? i tried to search this, but couldnt find anything.
Old May 23, 2003 | 05:38 PM
icy CL's Avatar
no need to do that. just remove the platic lining under the front fender...not the whole thing...just the front part of the lining. you'll need to remove a couple of clips to do that. then reach in deep...you'll be able to access the bulb. you'll need to turn counter clockwise to get the bulb holder out then slowly pull it out. the wires are long enough for you to be able to pull the whole thing out to change the bulb. put the new bulb in using either latex gloves (without the powdery stuff) or something to keep the oil of your hands off the bulbs. plug the whole thing back in slowly so as not to get grease or dirt on the bulbs. for the rears, just remove the trunk lining...the bulbs are very easy to access.
Old May 23, 2003 | 06:14 PM
nate'sCLS's Avatar
bout the easest mod you'll ever make
Old May 23, 2003 | 07:17 PM
Smitty's Avatar
Are you installing these??
http://www.sounddomain.com/sku/APC504129B
You just can't go wrong with a bulb like this that is has a 2 year warranty...
my front and rear turns 2 weeks ago... Looks awesome during the day now.. no more amber bulb showing during the day.
Smitty
Old May 23, 2003 | 07:41 PM
icy, when i reach down all i can access is the high beam bulb and the HIDS....how do i get to the turn signal bulb thats all the way to the right/left? i cant even see where the bulb is, its blocked off by a metal piece....thanks for the help
Old May 23, 2003 | 08:42 PM
Scooter's Avatar
'Cooter
http://www.acura-cl.com/forums/showt...5&pagenumber=2
look for my extra long post with pics
Old May 23, 2003 | 09:03 PM
Smitty's Avatar
Your not reaching down.. your on your back under the car and reaching way up into each corner.. A flash light helps. It is hard to see and a far stretch.
Old May 23, 2003 | 09:22 PM
icy CL's Avatar
sorry if i didn't explain it well enough. you need to go through via the wheel well.....not via the hood. if your doing the right side, turn the steering wheel all the way to the left to get better access to the right bulb. now go to the right wheel well, look up and remove the clips holding the plastic lining inside the wheel well. just remove the front ones...i think there are 2 or 3 screw type clips. then slowly pry out the plastic lining till the opening is big enough to fit your arms. you'll see the signal bulb holders straight ahead. a flashlight will help as smitty says. if doing the left side, turn the steering wheel all the way to the right. the rest is the same.
Old May 23, 2003 | 09:26 PM
Thanks for the help guys....really appreciate it!
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
HOWELLiNC
Sep 5, 2015 03:09 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
