Turbo?
on bin laden
Re: Turbo?
Originally posted by Inferno18
I havn't seen any turbo chargers for the CL -S out there. I was wondering if they have them in Japan? If not a Turbo than a supercharger.
Re: Re: Turbo?
Originally posted by fbazakos
there are some supercharger kits in the works. all the turbos i've seen are completely custom.
f-a-b-o-l-o-u-s
Originally posted by TypeSAddict
i have heard LOW estimates for the supercharger. like 50-60 hp. RES should get like 20-25, and mm2 would prolly be like 15. so, you should be around 85 additional hp.
13 Second CLS Defender :)
Originally posted by Styles__69
anyone know wat kind of hp gains were lookming at with the supercharger...res..and the mm2 kit???
1) Super/Turbo: both pressurize the intake manifold.. peak hp & tq will not be bumped significantly by the RES for the simple fact under boost the absolute manifold pressure should be *relatively* constant .. minimal gains if any there...
2) MMII : Modifies the IAT sensor.. again under boost your intake charge will heat up and the timing advance from tricking the ECU into thinking the charge is colder/hotter may cause a lean condition / detonation... **bad**
So in all.... if the gains from MMII & RES are aggregate they are a more cost effective solution to a Supercharger but I dont think they will work well at all in addition to a Super/Turbo...
joflewbyu2
10-08-2015 11:16 AM
