Turbo?
Old Apr 10, 2002 | 11:53 PM
Inferno18's Avatar
Turbo?
I havn't seen any turbo chargers for the CL -S out there. I was wondering if they have them in Japan? If not a Turbo than a supercharger.
Old Apr 10, 2002 | 11:54 PM
fbazakos's Avatar
on bin laden
Re: Turbo?
there are some supercharger kits in the works. all the turbos i've seen are completely custom.
Old Apr 11, 2002 | 07:19 AM
liquid_x's Avatar
Re: Re: Turbo?
people have had custom turbos done for 2nd gen CLs???
Old Apr 11, 2002 | 07:39 PM
Styles__69's Avatar
anyone know wat kind of hp gains were lookming at with the supercharger...res..and the mm2 kit???
Old Apr 11, 2002 | 07:49 PM
TypeSAddict's Avatar
is Pretty Much a Moron
i have heard LOW estimates for the supercharger. like 50-60 hp. RES should get like 20-25, and mm2 would prolly be like 15. so, you should be around 85 additional hp.
Old Apr 11, 2002 | 08:27 PM
my2sense's Avatar
f-a-b-o-l-o-u-s
if the damn thing ever comes out
Old Apr 11, 2002 | 08:30 PM
haiduc's Avatar
Moderator Alumnus
the res cant work for the 3.0 because the manifold is different.
i dont know about the mm2.
Old Apr 11, 2002 | 08:33 PM
nokio's Avatar
the RES cant work for any engine because it doesnt do anything........
Old Apr 11, 2002 | 08:44 PM
TheModMole's Avatar
13 Second CLS Defender :)
Your still looking at minimal gains... Because:
1) Super/Turbo: both pressurize the intake manifold.. peak hp & tq will not be bumped significantly by the RES for the simple fact under boost the absolute manifold pressure should be *relatively* constant .. minimal gains if any there...
2) MMII : Modifies the IAT sensor.. again under boost your intake charge will heat up and the timing advance from tricking the ECU into thinking the charge is colder/hotter may cause a lean condition / detonation... **bad**
So in all.... if the gains from MMII & RES are aggregate they are a more cost effective solution to a Supercharger but I dont think they will work well at all in addition to a Super/Turbo...
Old Apr 12, 2002 | 11:10 AM
Z's Avatar
Z
Then is that why comptech is making the supercharger for the clp which doesn't have a intake manifold like the cls??
skathe
2G TSX Performance Parts & Modifications
23
Apr 10, 2020 06:36 PM
Slow98teg
30
Jan 2, 2017 09:01 AM
mvidal6
ILX
Nov 14, 2015 07:43 AM
joflewbyu2
Oct 8, 2015 11:16 AM
CLsuperhero
Sep 23, 2015 12:53 PM
