Tune up
Old Apr 14, 2021 | 08:44 PM
Andyport101's Avatar
6th Gear
Tune up
Hey guys i was looking to get advice on a tune up on my 03 CL type S that just hit a little over 200 thousands miles not really sure what to tune up at this point besides filters spark plugs any ideas would help thanks an advance
Old Apr 14, 2021 | 08:59 PM
anything that is worn out or broken.
any fluids that havent been changed out in a while.
coolant, brake fluid, power steering fluid. any and all fluid.
brake pads and rotors?
suspension?
any thing that is broken.
fix it or replace said broken items.
how about hoses? any hoses that are brittle or weak? change them.
any corroded grounding cables? replace them.
basically look throughout the entire car to find anything that is broken or worn out.
Old Apr 14, 2021 | 11:41 PM
TheMightyQuinn's Avatar
Registered Nonmember
when was the last time the timing belt was replaced? It might be time.
Old Apr 15, 2021 | 09:22 AM
6th Gear
the timing belt and water pump were remplace about 7 Years ago i believe it had a bit under 150 thousands miles when it was replaced
Old Apr 15, 2021 | 11:38 AM
whitetiger5's Avatar
Anything that is worn out. though be careful; chances are that if you haven't been keeping up on maintaining all the various bits; you'll find things that need to be replaced on the way to replacing what you originally intended to replace. For example ignition coils when replacing spark plugs; or ball joints, bushings or tie rods when you just wanted to replace a few end links.
Old Apr 15, 2021 | 01:11 PM
619rcr's Avatar
recommend same as 105k service. such as spark plugs, timing belt and valve adjustment.
Old Apr 15, 2021 | 04:39 PM
TheWeez's Avatar
I Wanna Beer
Yup. This tuneup is every 105k miles OR every 7 years. Age is much more a concern with the timing belt and seals, than mileage. So I'd definitely do the timing belt, water pump, rear main seal, plugs, and valve adjustment now.
Old Apr 17, 2021 | 03:22 PM
Acura2g558's Avatar
My list for a tune-up
  • Spark plugs
  • Valve adjustment (only if the valve train is noisy)
  • Injector cleaner in the fuel tank
  • Oil Change
  • Transmission fluid change
  • Replace accessory belts, if worn/cracked
  • Drain and replace brake fluid (re-bleed calipers)
    • Lube caliper slide pins with silicone lubricant
    • Inspect and replace pads and rotors, if needed
  • Replace power steering fluid and re-bleed rack
  • Coolant drain and refill
  • Inspect suspension components for wear (Ball joints, sway bar links, bushings, etc.)
  • Perform idle relearn
  • Inspect exhaust for leaks
  • Inspect driveshafts and boots
  • Replace intake filter
  • Replace cabin filter
  • Inspect and replace timing belt + components
  • Replace Water Pump, if needed
  • Check for fluid leaks
  • Inspect tires
  • Check for burnt out bulbs (brake light, etc.)
That's everything I'd do for every 100k mile mark
Old Apr 17, 2021 | 03:23 PM
so, basically go throughout the entire car and see what items that need to be replaced either because it's broken or worn out.
lol
Old Apr 17, 2021 | 08:59 PM
Acura2g558's Avatar
lol
2ndgentl
Aug 3, 2013 08:28 PM
AcuraGman
Jul 27, 2010 12:54 PM
RaviNJCLs
May 24, 2008 02:30 PM
Keithisme
Aug 7, 2003 05:43 PM
scalbert
Oct 15, 2002 08:12 PM
