Transmission
Old Sep 14, 2006 | 11:17 PM
eddie30013's Avatar
2003 ABP CL Type-S
Transmission
I am planning on flushing my tranny with some synthetic fluid. Does anyone know how many quarts I need?
Old Sep 14, 2006 | 11:29 PM
Allout's Avatar
Blown is Best
When I did mine, I used 10-12 quarts before I got clean fluid.
Old Sep 14, 2006 | 11:36 PM
eddie30013's Avatar
2003 ABP CL Type-S
What kinda fluid did you use?
Old Sep 14, 2006 | 11:48 PM
spiderman3098's Avatar
use the cheapest fluid u can find to flush everything out once clean drain and filler-her up with geniune honda tranny fluid.
Old Sep 14, 2006 | 11:51 PM
eddie30013's Avatar
2003 ABP CL Type-S
I was thinking about getting some amsoil synthetic because my friend can hook me up with that
Old Sep 14, 2006 | 11:56 PM
aznxtallxboy's Avatar
according to HELMS, it's 3.1 quarts just to change, for a total flush, it's 7.6 quarts. and also, it only recommends using Honda ATF-Z1 fluid.
Old Sep 15, 2006 | 12:23 AM
Allout's Avatar
Blown is Best
That's exactly what I used. Amsoil is very good stuff and is Z1 rated. I highly recommend. The tranny will behave much more stable with synthetic in it. Shifts will be more consistent. You won't have the differences in shifts between cold, normal operating temps and after a hard hot run.
Old Sep 15, 2006 | 12:34 AM
eddie30013's Avatar
2003 ABP CL Type-S
cool, thanks for the advice!
Old Sep 15, 2006 | 03:00 AM
BigLizard's Avatar
Moderator Alumnus
Use synthetic grade. It's all our trannies take.
Old Sep 15, 2006 | 10:49 AM
JadeFox's Avatar
yay! for SRS xtension
could that improve the hella workload i give my tanny? actually make it feel and run better...when i poped in my mobil1 for the first time it was like smooth as silk...im just afraid to go against the ONLY use hondaATF , may void your tranny warrenty too no?
Old Sep 15, 2006 | 02:21 PM
YeuEmMaiMai's Avatar
Only way it will void warranty is if the fluid was not to the same specs as honda atf or better. Personally I would not use any thing other than Honda ATF
Old Sep 15, 2006 | 02:56 PM
BigLizard's Avatar
Moderator Alumnus
Old Sep 15, 2006 | 05:01 PM
Sun Diego CL-S's Avatar
says "hello to my TLX".
i gotta get my hands on one of these. good advice, fellas.
Old Sep 15, 2006 | 06:33 PM
eddie30013's Avatar
2003 ABP CL Type-S
Its not like they can tell what kind of fluid you put in there
Old Sep 15, 2006 | 07:10 PM
wanna bet? They can do a SOS analisys on the trans fluid
Old Sep 15, 2006 | 10:51 PM
Allout's Avatar
Blown is Best
Amsoil Synthetic ATF meets Honda Z-1 specs.
http://www.amsoil.com/StoreFront/atf.aspx
Do you only take your car to the dealer for service too?
Old Sep 15, 2006 | 10:56 PM
Allout's Avatar
Blown is Best
Amsoil rates their fluid to meet Honda Z-1 specs. They would have to prove why Amsoil did not meet Z-1 specs in order to void your warranty. Plus, with the trannys having a history of failure, they would not be too successful arguing that their tranny's are reliable when only using factory fluid and that the aftermarket fluid which is rated to meet their spec was the culprit.
If Honda Z-1 was the only thing that would keep your warranty intact, the same principal would apply to brake fluid, motor oil, coolant, windshield washer fluid, etc.
Old Sep 16, 2006 | 12:07 PM
what's that got to do with anything?
I just love people like you who try to be smart...funny that I take my car to dealer for major service and when I have problems with something breaking out of warranty, I usually get some kind of assistance from Honda...... either dealer gives a SUBSTANTIAL DISCOUNT or HOA picks up the tab entirely...for example the alt in my previous car '98 accord died at 99K and it was i paid for labor only.........
Now they do the routine matint on my CL-S and I think it's nice at my point in like to NOT HAVE TO WORK ON MY CAR
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
