Throttle problem!
Old Nov 24, 2008 | 06:38 PM
loweredCL's Avatar
Throttle problem!
Hey guys,
I asked this before but the answer didn't solve the problem. The problem is with my 6 speed, when I get off the throttle, the RPM's stay up. I pulled off my CAI and cleaned around the throttle body, and the TB moves easily and the spring has good tension. Any other suggestions?? Thanks.
Old Nov 24, 2008 | 09:16 PM
poisx7's Avatar
for how long does the rpm stay up b4 it starts to drop ???
Old Nov 24, 2008 | 09:34 PM
loweredCL's Avatar
the best way I can answer that, is I get ready to change gears, take my foot off the gas, then press in the clutch, shift gears and the RPM's haven't dropped yet. Even if I'm just sitting in place and blip the throttle, it goes to a point, hesitates for a sec, then comes back down, slowly. I didn't notice it before I added my CAI, could that be it? Too much air keeping the throttle open?? Thanks
Old Nov 24, 2008 | 09:39 PM
YL Al's Avatar
i dont think its the cai, unless it was improperly installed.how many miles you have on the engine?
Old Nov 24, 2008 | 09:40 PM
loweredCL's Avatar
I have 58,000, that's all.
Old Nov 24, 2008 | 09:41 PM
Moodist's Avatar
Unless it is very excessive or shooting up, its probably the nature of the dual mass flywheel, it keeps the revs up while changing gears.
Old Nov 24, 2008 | 09:43 PM
YL Al's Avatar
you may have a nasty ecu(input coordination=FAILURE) or heavy flywheel.
Old Nov 24, 2008 | 09:50 PM
YL Al's Avatar
im guessing it doesnt lag at full throttle right?
probably ECU more than anything,since it wasnt like this before. geta retune or try cleaning your iacv see if that helps any.
Old Nov 24, 2008 | 09:52 PM
loweredCL's Avatar
Sorry, what is an IACV?
Old Nov 24, 2008 | 09:54 PM
YL Al's Avatar
its the idle air control valve. gets filled with grease. cleaning it may help a lil.
check to see if theres any instructions in the 2nd gen forum,i would think they have a DIY for cleaning the valve.
Old Nov 24, 2008 | 10:04 PM
YL Al's Avatar
allright dude if no body gets you going then ill be on tommorrow to check your thread
good night
Old Nov 24, 2008 | 10:09 PM
Pinho's Avatar
if its not the IACV or could be a bad throttle cable that has crap in it
Old Nov 24, 2008 | 10:28 PM
aznboi2424's Avatar
sticky throttle?
Old Nov 24, 2008 | 11:08 PM
nspec_ya4's Avatar
Regional Coordinator (Texas)
you need to clean that cable by the throttle body w/ a carb cleaner and then grease it up. more than likely that will sove your problem
SidhuSaaB
May 30, 2020 12:40 AM
LoneRonin
Jan 4, 2016 01:03 AM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
