throttle body
throttle body
hey guys I went to rick Case Acura to get some work done and the service advisor said that my throttle body was dirty and if I want them to fix it ...Its going to be $168.....Have any of you had to clean it b4 if so how??????
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
TQ > MPG
$5 will get you a bottle of TB cleaner at your local AutoZone. Take off the intake tubing and spray it in there and wipe off any excess oil with a rag. That's all they'll do at the stealership.
GEEZER
They had to replace mine at 32k miles.
If the car is off then the throtle flap is closed. do you need to open that and spray the cleaner in there also?
Ive installed an Icebox on my car and when i did i took a look at the TB, it doesnt look like there is much in there to get dirty. can someone explain what exactly get dirty?
contaminant build up is usually found in the TB bore where the butterfly valve disc contacts the bore. and directly adjacent to this location. if left dirty this will result in the valve disc sticking compromising throttle response rough idle and loss of power/fuel mileagen
usually this doesnt happen much as present day fuels the have additives to eliminate deposits. contaminents come with ingested air which is poorly filtered or with leaky (air) bellows which might allow unfiltered air to enter TB. inspect each 50k and if deposits are present, clean as noted above also check air box and TB inlet clamps and tighten/replace if needed. in dusty or salt ed locals contamination is more prevalent
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
