Thermoblok Spacers Installed.....is this normal?
What to do, what to think
Couple of days ago I just installed my Thermoblok spacers...everything is normal, no codes, no rough idle, no check engine light. The Car definitely pulls nice and the Intake Manifold.....I can now rest my hand on it .....the only thing I've noticed that everytime I hit the gas hard....I hear a whisle coming out of my hood. Is this normal? I mean everything is fine and the car runs great . Possible air leak? I checked everything and seems good to me. I followed one of the members (forgot who it was...but thank you ) DIY link : http://photos.phytte.com/view_album....okInstallation
Call me stupid but this is my first time installing something decent on my car
I'm equipped with a AEM CAI. Wanted to check the spacers out before supercharging the car
Originally Posted by dshearon
i have the same thing.... AEM CAI and TB spacers... i am getting the whistle and have tripple checked to make sure everything was tourqued correctly.... the whistle only happens when i push it hard around 3000 rpm..
Really....thats what I did.....I'd made sure everything was torque correctly too.....
now my car sounds like that JDM C-west S2000 that once been driven by Orido Manabu (Advan Driver/Drifter) on best motoring. everytime that car hits the gas at a certain high rpm it whisle's......sounds pretty cool though ...or maybe its the AEM CAI thats making the sound instead of the INJEN intakes correct me if I'm wrong....
Never had a clean run
Yep, I got the same thing. Torqued everything appropriately too. Maybe it's the really rough edges of the thermoblok spacers causing air resistance which causes that whistling noise. I would assume that most people have it but just cannot hear it since they have to be next to a wall while revving or inside a parking garage. That's the only time I can hear it clearly.
Received 1,080 Likes
That's exactly what's causing it. Nothing to worry bout.
today I was locating the whistling sound under my hood and its coming from my TB and intake? I re-torqued the bolts and its still doing it.....anyone? normal or what? but although it sounds cool
I guess its normal then . allmotor, did you sell your custom turbo kit? I remember there was a thread that talked about you sold the kit....are u planning on doing another project? bigger garret turbo kit?
Originally Posted by typeR
i didnt do the TB spacer just upper/lower intake...plus i have the ice box and i dont hear a whistle ...maybe its from the TB spacer?
I figured it was the TB spacer and the CAI intake.....not to mention I put my ear right on the TB while my friend was hitting the gas pedal so its not coming from the Manifold spacer......not to mention my ears almost exploded while doing it 5 times....
Awesome... I am glad you fonud the cause. I am guessing the TB is not really doing any good if i am already bypassing the coolant line correct. if that is the case i may take it out.
dshearon I think you should be fine with the coolant bypass since you live in Florida with the hot weather . I didn't do the bypass because during fall and spring season it gets pretty cold in my area which it sucks .
Adventurist.
Originally Posted by Oakroadsteve
I tried your link for the install but it did not work. Are there any other links for the Thermoblock install? I did a search and could not find one.
Originally Posted by RaviNJCLs
I used the instructions I got with the spacers. They were fine.
How long did it take to install?
Did you have to make any modifications?
Thanks for the heads up.
Just curious but what would happen if I do the coolant bypass and live in a cold winter climate? I rarely drive the car in the cold/snow so would it be ok?
I live in Chicago and have my TB coolant lines by passed. I left them by passed for the winter to see if anything happened. I have driven it several days when the temperature was in the single digits with no problems.
says "hello to my TLX".
yeah. the instructions didn't recommend doing that in colder regions. for example Chicago, bbrrrr! that's cool that everything is cool and all but, i don't think that bypass is of much benefit. i had mine setup like that and always came to find that the hose was hotter than shit. so i decided to just hook up everything back. unless someone's dyno says otherwise.
Adventurist.
the reason i disconnected that is because i could have sworn that the line wasn't as hot as it started to get. so i thought something could've started to screw up and heat the engine more. it was just my nerves. in that case, let me go open my hood and redo that chit. thanks dustin.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
