Thermoblok Spacers Installed.....is this normal?
Old Aug 21, 2005 | 02:04 AM
CL FWD SPEED's Avatar
What to do, what to think
Red face Thermoblok Spacers Installed.....is this normal?
Couple of days ago I just installed my Thermoblok spacers...everything is normal, no codes, no rough idle, no check engine light. The Car definitely pulls nice and the Intake Manifold.....I can now rest my hand on it .....the only thing I've noticed that everytime I hit the gas hard....I hear a whisle coming out of my hood. Is this normal? I mean everything is fine and the car runs great . Possible air leak? I checked everything and seems good to me. I followed one of the members (forgot who it was...but thank you ) DIY link : http://photos.phytte.com/view_album....okInstallation
Call me stupid but this is my first time installing something decent on my car
I'm equipped with a AEM CAI. Wanted to check the spacers out before supercharging the car
Old Aug 21, 2005 | 09:40 AM
typeR's Avatar
no its not normal
Old Aug 21, 2005 | 01:37 PM
dshearon's Avatar
i have the same thing.... AEM CAI and TB spacers... i am getting the whistle and have tripple checked to make sure everything was tourqued correctly.... the whistle only happens when i push it hard around 3000 rpm..
Old Aug 21, 2005 | 03:06 PM
NiteQwill's Avatar
Adventurist.
I have the same setup. I do not get a whistle.
Old Aug 21, 2005 | 03:19 PM
6MTpromises's Avatar
Relax!
ditto, me neither.
Old Aug 21, 2005 | 03:48 PM
Really....thats what I did.....I'd made sure everything was torque correctly too.....
Old Aug 21, 2005 | 03:50 PM
Originally Posted by typeR
no its not normal
man......what can be the cause? is it really bad?
Old Aug 21, 2005 | 03:53 PM
now my car sounds like that JDM C-west S2000 that once been driven by Orido Manabu (Advan Driver/Drifter) on best motoring. everytime that car hits the gas at a certain high rpm it whisle's......sounds pretty cool though ...or maybe its the AEM CAI thats making the sound instead of the INJEN intakes correct me if I'm wrong....
Old Aug 21, 2005 | 05:38 PM
dshearon's Avatar
i dunno what is causing it... one of these days when i get motivated i am going to replace all the gaskets and re-torque everything and see if it goes away
Old Aug 21, 2005 | 06:14 PM
rtatsutani's Avatar
Never had a clean run
Yep, I got the same thing. Torqued everything appropriately too. Maybe it's the really rough edges of the thermoblok spacers causing air resistance which causes that whistling noise. I would assume that most people have it but just cannot hear it since they have to be next to a wall while revving or inside a parking garage. That's the only time I can hear it clearly.
Old Aug 21, 2005 | 08:10 PM
NSXNEXT's Avatar
That's exactly what's causing it. Nothing to worry bout.
Old Aug 24, 2005 | 06:35 PM
today I was locating the whistling sound under my hood and its coming from my TB and intake? I re-torqued the bolts and its still doing it.....anyone? normal or what? but although it sounds cool
Old Aug 24, 2005 | 11:26 PM
allmotor_2000's Avatar
You know... I just heard that whistle. My car was too loud before with the turbo... but on part throttle I heard it... wow!
Old Aug 25, 2005 | 12:59 PM
I guess its normal then . allmotor, did you sell your custom turbo kit? I remember there was a thread that talked about you sold the kit....are u planning on doing another project? bigger garret turbo kit?
Old Aug 25, 2005 | 01:44 PM
Yup, its gone!
Old Aug 25, 2005 | 01:46 PM
typeR's Avatar
i didnt do the TB spacer just upper/lower intake...plus i have the ice box and i dont hear a whistle ...maybe its from the TB spacer?
Old Aug 25, 2005 | 03:48 PM
I figured it was the TB spacer and the CAI intake.....not to mention I put my ear right on the TB while my friend was hitting the gas pedal so its not coming from the Manifold spacer......not to mention my ears almost exploded while doing it 5 times....
Old Aug 25, 2005 | 04:23 PM
dshearon's Avatar
Awesome... I am glad you fonud the cause. I am guessing the TB is not really doing any good if i am already bypassing the coolant line correct. if that is the case i may take it out.
Old Aug 25, 2005 | 09:03 PM
I went to see this tech. I know from a performance shop and he said everything should be fine and he also mentioned its gotta be the TB spacers and the CAI intake since the thermoblock is doing its job to reduce heat air. I've noticed before when I drove my car without warm up during the winter (just to re-park my car), the CAI intake made a lot of hissing sound....after the car warms up entirely the sound is gone. He also garrantees that when I supercharge my car and the icebox will take place I won't have the whistle noise anymore since the TB spacers and the CAI will be out. Generally, the intake manifold spacer is doing most of the job, from his . as long as the car pulls nice and drives normal
dshearon I think you should be fine with the coolant bypass since you live in Florida with the hot weather . I didn't do the bypass because during fall and spring season it gets pretty cold in my area which it sucks .
Old Feb 14, 2006 | 12:03 PM
Oakroadsteve's Avatar
I tried your link for the install but it did not work. Are there any other links for the Thermoblock install? I did a search and could not find one.
Old Feb 14, 2006 | 12:08 PM
NiteQwill's Avatar
Adventurist.
Sorry, my website went down. Let me try to find a backup.
Old Feb 14, 2006 | 01:12 PM
RaviNJCLs's Avatar
I used the instructions I got with the spacers. They were fine.
Old Feb 15, 2006 | 07:20 AM
Thanks for the heads up.
How long did it take to install?
Did you have to make any modifications?
Old Feb 15, 2006 | 07:38 AM
RaviNJCLs's Avatar
It took about 2 to 3 hours. I cleaned out the TB while I had it out. I didn't have to make any modifications.
Old Feb 15, 2006 | 09:08 PM
Nitz's Avatar
Just curious but what would happen if I do the coolant bypass and live in a cold winter climate? I rarely drive the car in the cold/snow so would it be ok?
Old Feb 16, 2006 | 08:05 AM
dj5's Avatar
dj5
I live in Chicago and have my TB coolant lines by passed. I left them by passed for the winter to see if anything happened. I have driven it several days when the temperature was in the single digits with no problems.
Old Feb 16, 2006 | 09:41 AM
Sun Diego CL-S's Avatar
says "hello to my TLX".
yeah. the instructions didn't recommend doing that in colder regions. for example Chicago, bbrrrr! that's cool that everything is cool and all but, i don't think that bypass is of much benefit. i had mine setup like that and always came to find that the hose was hotter than shit. so i decided to just hook up everything back. unless someone's dyno says otherwise.
Old Feb 16, 2006 | 10:30 AM
NiteQwill's Avatar
Adventurist.
That's the point. You DON'T want that hot hose running the coolant through your TB, it just heats up the air in your TB. With no hose hooked up, you have zero heat transfer from the coolant.
Old Feb 16, 2006 | 10:34 AM
the reason i disconnected that is because i could have sworn that the line wasn't as hot as it started to get. so i thought something could've started to screw up and heat the engine more. it was just my nerves. in that case, let me go open my hood and redo that chit. thanks dustin.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
rockyboy
Oct 2, 2015 10:45 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
