Sways just in
Old May 11, 2002 | 09:31 PM
pkane's Avatar
Old Fella
Sways just in
Thanks to MackDaddy, I completed my Sway install this afternoon in about 2 1/2 hours. What a diff! I have a freeway onramp near me that I often take at 45. I just took it a 60 with the sways!
The car just rides like a slot car now. I love it!
Best to all!
Old May 11, 2002 | 09:33 PM
Rescuer's Avatar
Evil Bob Knieval
the sways take 20 minutes to install
glad you like them, the springs make you handle better WAY more than the sways
Old May 11, 2002 | 11:28 PM
Red Rider's Avatar
Subie Dubie
Best mod for the $
Old May 12, 2002 | 08:24 PM
Dom418's Avatar
I LOVE MY CAR
Does anybody have a link to the Sway bar install instructions... I used Search and only found bits and pieces of advice..
anything out of the ordinary I need to watch out for??
thanks,
DOM
Old May 12, 2002 | 08:55 PM
bnavarro's Avatar
Got BOOST????
Dom418,
it's mad easy. did u order them yet. they come with instructions. if u have problems, someone from the site will help, maybe even me.
Pkane,
just wait till u get springs or coilovers. even a bigger difference.
Old May 12, 2002 | 08:57 PM
Austin519's Avatar
TypeSDragoon:
No way man...sways kill springs...did you do springs then sways, or sways then springs? Maybe it's just that you got the Comptech sways heh heh.
Dom418:
I wrote up a nice big FAQ last night with a lot of pics. Adam should be putting it up here soon.
Austin519
Old May 13, 2002 | 01:56 AM
ChopSuey's Avatar
Down The Of System
Now you gotta get rid of those Squeaky stocks and get some Toyos!!
Old May 13, 2002 | 07:50 AM
Dom418's Avatar
I LOVE MY CAR
Originally posted by Austin519
TypeSDragoon:
Dom418:
Austin519
Thanks Autsin519! I'm sure I could have gotten through it.. dosen't sound like there's a whole lot to it....
THANKS!
DOM
Old May 13, 2002 | 07:52 AM
Dom418's Avatar
I LOVE MY CAR
Originally posted by bnavarro
Dom418,
Bnavarro....
I have them sitting in my Garage... no instrux, i bought from Crazy Acura in his mod Liquidation.....
It sounds pretty straight forward... thanks
DOM
Old May 13, 2002 | 02:43 PM
Austin519's Avatar
Dom418:
I just uploaded a zip of the faq...soopa should have it up on www.acura-cl.com/garage2 soon...now is that it's final resting place...no idea
Austin519
Old May 13, 2002 | 03:03 PM
Dom418's Avatar
I LOVE MY CAR
Dom418:
Austin519
Thanks Austin519
I'll take a look for it....
DOM
Old May 15, 2002 | 09:28 AM
pkane's Avatar
Old Fella
Dom418
The biggest thing to the install is removing the old muthas & that is made easy by using a pair of needle nose vice grips to hold the endlink while you put a 14 mm socket on the nut. There is no other way to hold the stud! What a crazy design! I went out and bought a pair of vice grips for the job ($11.00) and it went like clockwork!
Good luck! Actually, it doesn't even take luck!
Old Fella
Old May 15, 2002 | 09:55 AM
Dom418's Avatar
I LOVE MY CAR
Originally posted by pkane
Dom418
Old Fella
Thanks... I'm sure I'll be fine, I haven't even looked at it yet, so I really didn't know what to expect.
DOM
Old May 15, 2002 | 03:01 PM
bnavarro's Avatar
Got BOOST????
Dom418
Old Fella
don't use the vice grips. there is an allen key slot on the stud. use the allen key to hold the stud instead. the vice grips will make marks on the thread and make it a pain in the ass to put the nut back on. not sure the size on the allen key though. may be 6 mm.
Old May 15, 2002 | 03:39 PM
typesontheprowl_RENAMED's Avatar
Comptech Web Site has the install instructions. Here is the link:
http://www.comptechusa.com/instructions/921050.pdf
There is a slight adjustment to the directions. On the sheet, it mentions the use of lubricant. The kit no longer comes with the grease, it comes with white plumber's teflon tape. If your used kit didn't have it, just go down to your local hardware store and get a roll. Should be about a $1. Wrap the rear bar with the teflon tape where the replacement bushings are to be installed. That is the only change to the directions. Looks like the other posts offer good tips. Good luck. It is an awesome mod!!!
Old May 15, 2002 | 04:05 PM
Old May 16, 2002 | 10:37 PM
pkane's Avatar
Old Fella
There is no allen key that I saw! And the vice grips don't go on the threads - they go on the back side where they don't cause any problem. There is enough room to slip them in behind if they are small needle nose vice grips. Unless you can enlighten me, I didn't see any allens at all! I guess it's "whatever works", right?
Regards,
Pete
Old May 17, 2002 | 03:20 PM
bnavarro's Avatar
Got BOOST????
i'll take pixs tomorrow and post them.
Old May 19, 2002 | 05:38 PM
bnavarro's Avatar
Got BOOST????
i circled the where you can put the allen key to hold the stud. just use a wrench to take off the nut. i think it's a 5 mm allen that fits it.
Old May 19, 2002 | 08:56 PM
Austin519's Avatar
pkane:
Yeah I dunno man...but there is an allen key that goes in the end.
Dom418:
Adam hasn't had a chance to post my FAQ yet...I can email you the zip if you give me your email address.
Austin519
Old May 19, 2002 | 09:20 PM
Dom418's Avatar
I LOVE MY CAR
pkane:
Dom418:
Austin519
Thanks AUstin, that would be great...
e-mail -> PappalardoD@McdMgmt.com
.... thanks,
DOM
Old May 20, 2002 | 11:56 AM
Austin519's Avatar
Dom418:
Sent bud go check your email!
Austin519
Old May 20, 2002 | 12:07 PM
Dom418's Avatar
I LOVE MY CAR
Dom418:
Austin519
thanks, DOM
Old May 20, 2002 | 09:44 PM
pkane's Avatar
Old Fella
Here's my pic. I still (for the life of me) don't see where an allen wrench would go!
Old May 21, 2002 | 07:20 PM
Austin519's Avatar
Dom418:
pkane:
See that top end link? The one attached to the swaybar? On the other side of it, there is a bolt and nut sticking out. That bolt has a hole in it, the hole being a hex (allen) wrench shape. That is where you put it.
Austin519
Old May 21, 2002 | 08:48 PM
bnavarro's Avatar
Got BOOST????
Dom418:
pkane:
Austin519
the allen key goes inside the stud that the nut is on.
Old May 22, 2002 | 12:51 AM
frank828's Avatar
im not sure if ur cars come with them, but my Accord V6 comes with a little tool that is used to manually open the moonroof. I hear that tool is pefect for this job. My tool is in my stock toolbox in my trunk.
Old May 22, 2002 | 05:58 AM
MikeS 18's Avatar
Adult Supervision
Here's my pic. I still (for the life of me) don't see where it would go!
Pkane,
You dont' have this problem with girls do you?
Old May 22, 2002 | 08:50 AM
bnavarro's Avatar
Got BOOST????
Originally posted by MikeS 18
Pkane,
Old May 22, 2002 | 08:41 PM
pkane's Avatar
Old Fella
Pkane,
You know, now that you mention it.....
Actually, with girls I use the touch it, feel it system - rather than seeing it! Works pretty well!
Thanks for the jab! Later
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
steve
Sep 30, 2015 09:23 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
