sway bars
Old Oct 5, 2003 | 04:51 PM
asloudasitgets's Avatar
sway bars
i have a set of comptech sway bars on my car and just put them on about 1 1/2 weeks ago and already am having squeeking problems.... i was just wondering if i run out of tape , then what can i use to stop the squeeking.... like what other lub. can you use???? damn squeeking already
and also if i want to add more tape to the sway bushing , then do i have to take off the whole bar or can i take off the bushing/ tape and replace it with new tape????
Old Oct 5, 2003 | 05:22 PM
gsrblack's Avatar
Try looking into swapping out the bushings...I believe somebody here said that CT has a rubber bushing for the bars.
Old Oct 5, 2003 | 05:53 PM
lead_sled_dog's Avatar
Back to Four Doors
Re: sway bars
Head down to your local auto parts store and ask for some high grade grease for bushings and bearings. Get rid of the tape and grease those puppies to eliminate the squeaks ...
Just loosen the sway bar at the bushings, pop 'em off, grease 'em and replace. Voila ... no more squeaks.
Old Oct 5, 2003 | 06:07 PM
civic4982's Avatar
SHIFT_over.so.I.can.see
I used the grease... it's great... 2 months and no squeaking so far...
Old Oct 5, 2003 | 06:32 PM
Jens H.'s Avatar
retired
I use plain old black axle grease ,it only needs to be regreased every 12 months or so .
Jens
Old Oct 5, 2003 | 06:52 PM
Crazy Bimmer's Avatar
when i installed mine, i didnt even use the tape. I just greased them up really well. Worked fine.
Old Oct 5, 2003 | 09:06 PM
thanks for the responses.
coudl you guy reccomend any grease?
is there a brand?
Old Oct 5, 2003 | 09:56 PM
AgentDSS's Avatar
Black is a ***** to Clean
asloudasitgets: when do you hear the squeaks? while driving on a bumpy road? or only when turning and stuff?
Old Oct 6, 2003 | 03:57 AM
Shawn S's Avatar
I had mine installed in the spring of 2002 by Park Avenue Acura.
They just started to squeak a few weeks ago.
I have an appointment with them next week for my 15K service and that’s one of the things they’re addressing.
Shawn S
Old Oct 6, 2003 | 03:59 AM
Jens H.'s Avatar
retired
I am using Sta-Lube wheel bearing grease .WOrks well lasts long is very cheap .
Jens
Old Oct 6, 2003 | 05:21 AM
scalbert's Avatar
All I have used and no squeaks
Old Oct 6, 2003 | 05:27 AM
darrinb's Avatar
///M POWER
do the eibach sways sqweek too??
Old Oct 6, 2003 | 06:12 AM
danny25's Avatar
I'm sure they would if not greased properly. But so far, no squeaks.
Old Oct 6, 2003 | 08:59 AM
the noise is when i go over a speed bump. not while driving.
tsx_boy
Dec 13, 2019 08:33 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
hashbrown
Sep 29, 2015 12:13 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
