Supercharge leaking Question.
Old Oct 13, 2004 | 01:35 AM
sgmotoring's Avatar
Bleed Honda Blue
Hi can anyone with a supercharge tell me what goes to that hole? Am I missing a hex plug? I heard a hissing noise and found a missing hex plug, screw or another fitting. I think that leaking hole rob me of .5 psi of boost.
Old Oct 13, 2004 | 08:29 AM
ModAddict's Avatar
Yes it is leaking , or sucking, vacuum! You need to plug that up.
Old Oct 13, 2004 | 08:42 AM
scalbert's Avatar
Yes, that should be closed. I forgot the actual size but is is a standard thread and not a fitting. I believe it is a 10-32 thread. A 3/8 length should be more than enough.
Old Oct 13, 2004 | 12:40 PM
nicholbr's Avatar
i swear to god, take your camera and randomly take a picture of any part of the CL and scalbert will tell you the width, thread size, length and part # of any bolt you might be missing. And then, if your lucky, he'll tell you how to make intercoolers. ha!
your the man dude, i can only hope i'll have that knowledge one day
Old Oct 13, 2004 | 12:47 PM
allmotor_2000's Avatar
If there's a leak before the T/B (and after the S/C), you will see a drop in boost if the leak is significant enough. If you are hearing a 'hiss' at idle, its after the T/B and that's the the sound of vacuum (engine is sucking in air through that instead of the T/B) - idle should be higher!!
Old Oct 13, 2004 | 12:50 PM
scalbert's Avatar
Remember, the TB is before the SC in this case. This is in the Comptech elbow which attaches to manifold where the TB sits in the stock location. So it is under vacuum and boost. Regardless, it should be plugged.
Old Oct 13, 2004 | 03:25 PM
sgmotoring's Avatar
Bleed Honda Blue
I would like to know what was there? hex plug? I am currently using a screw to plug that leak. .
Old Oct 13, 2004 | 04:57 PM
scalbert's Avatar
It was a allen head screw.
Old Oct 13, 2004 | 06:56 PM
sgmotoring's Avatar
Bleed Honda Blue
Thanks, I hope that allen head plugs fell out and not in.
Old Oct 14, 2004 | 06:36 AM
scalbert's Avatar
Well, it was a cap screw so it shouldn't have gone in.
Mike734
Dec 10, 2021 01:25 PM
Avenger411
Oct 11, 2015 03:53 PM
steve
Sep 30, 2015 09:23 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
