Supercharge leaking Question.
Bleed Honda Blue
Hi can anyone with a supercharge tell me what goes to that hole? Am I missing a hex plug? I heard a hissing noise and found a missing hex plug, screw or another fitting.
I think that leaking hole rob me of .5 psi of boost.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Yes, that should be closed. I forgot the actual size but is is a standard thread and not a fitting. I believe it is a 10-32 thread. A 3/8 length should be more than enough.
your the man dude, i can only hope i'll have that knowledge one day
If there's a leak before the T/B (and after the S/C), you will see a drop in boost if the leak is significant enough. If you are hearing a 'hiss' at idle, its after the T/B and that's the the sound of vacuum (engine is sucking in air through that instead of the T/B) - idle should be higher!!
Remember, the TB is before the SC in this case. This is in the Comptech elbow which attaches to manifold where the TB sits in the stock location. So it is under vacuum and boost. Regardless, it should be plugged.
![:O](https://acurazine.com/forums/images/smilies/embarrassment.gif)
Bleed Honda Blue
Remember, the TB is before the SC in this case. This is in the Comptech elbow which attaches to manifold where the TB sits in the stock location. So it is under vacuum and boost. Regardless, it should be plugged. ![:O](https://acurazine.com/forums/images/smilies/embarrassment.gif)
Originally Posted by sgmotoring
I would like to know what was there? hex plug? I am currently using a screw to plug that leak.
Joe Avesyan
09-29-2015 03:57 PM
