Subwoofer
Originally posted by amirsafdari:
<STRONG>i was just wondering, do our head units have fuses, so if like the head unit stops sending signal to only 1 of the speakers in the car, can this be fixed without relacing the head unit..?</STRONG>
Originally posted by SilverKnight:
<STRONG>
nope ... if the fuse is blown, the whole unit goes out. If one of the channel doesn't work, the head unit is screwed, but in our case ... dont forget the problem may be with the stock amp.</STRONG>
<STRONG>
then for my situation, could i just make a "y" wire going to the 1 rear speaker that isnt working, from the one that is working..?
<STRONG>oh and could the stock amp cause just 1 speaker to go out?</STRONG>
Thats my understanding tho.
Originally posted by GOT PSI?:
<STRONG>I will adding an Orion amp & a pair of EV 15" running free air...as soon as its done i'll post all the pics.</STRONG>
Originally posted by Dyno_CL-S:
<STRONG>
why a free air sub?? I dont like the way the bass sounds. If you like tight bass then go with some 10' sealed enclosure sub's. Again, if you want to consume the least amount then go with one and u'r sh^t will sound great. Thats my taste tho.</STRONG>
<STRONG>
<STRONG>how much would it cost to replace the stock amp..?
can i use ANY amp for the stock system?
I have a 600watt kenwood, can i use that for the stock system? AS WELL AS using it for two subs..?</STRONG>
AndrewS
19
03-14-2024 06:59 PM
BoricuaTL
04-08-2016 01:08 PM
kb1rl
09-30-2015 10:17 AM
3GTLOwns
09-09-2015 09:51 PM
