Subwoofer
Old Jul 21, 2001 | 05:30 PM
acura_service's Avatar
www.drippinwet.com
Subwoofer
anyone added one to the blose sound system?
Old Jul 21, 2001 | 05:37 PM
1StGenCL's Avatar
958 & 991
Lots of people have. Do a search in either car talk or the a/v section and you should find pretty good instructions
Old Jul 21, 2001 | 06:40 PM
amir was here's Avatar
i was just wondering, do our head units have fuses, so if like the head unit stops sending signal to only 1 of the speakers in the car, can this be fixed without relacing the head unit..?
Old Jul 22, 2001 | 05:27 AM
SilverKnight's Avatar
Retired. Not available.
Originally posted by amirsafdari:
<STRONG>i was just wondering, do our head units have fuses, so if like the head unit stops sending signal to only 1 of the speakers in the car, can this be fixed without relacing the head unit..?</STRONG>
nope ... if the fuse is blown, the whole unit goes out. If one of the channel doesn't work, the head unit is screwed, but in our case ... dont forget the problem may be with the stock amp.
Old Jul 22, 2001 | 08:40 AM
Originally posted by SilverKnight:
<STRONG>
nope ... if the fuse is blown, the whole unit goes out. If one of the channel doesn't work, the head unit is screwed, but in our case ... dont forget the problem may be with the stock amp.</STRONG>
oh shit, this is not good...
then for my situation, could i just make a "y" wire going to the 1 rear speaker that isnt working, from the one that is working..?
Old Jul 22, 2001 | 08:58 AM
oh and could the stock amp cause just 1 speaker to go out?
Old Jul 22, 2001 | 03:34 PM
Dyno_CL-S's Avatar
<STRONG>oh and could the stock amp cause just 1 speaker to go out?</STRONG>
Yes. You could have a "channel" f^cked up or a.k.a. a "blown" one, for whatever reason. If you have one that no signal is gooing to that/those speakers or the signal is very distored. The same could be true of any car radio. It's usually not worth it to repair the unit then to go out anbd buy another one.
Thats my understanding tho.
Old Jul 22, 2001 | 04:03 PM
GOT PSI?'s Avatar
It's Go-Time.
I will adding an Orion amp & a pair of EV 15" running free air...as soon as its done i'll post all the pics.
Old Jul 22, 2001 | 04:22 PM
Dyno_CL-S's Avatar
Originally posted by GOT PSI?:
<STRONG>I will adding an Orion amp & a pair of EV 15" running free air...as soon as its done i'll post all the pics.</STRONG>
why a free air sub?? I dont like the way the bass sounds. If you like tight bass then go with some 10' sealed enclosure sub's. Again, if you want to consume the least amount then go with one and u'r sh^t will sound great. Thats my taste tho.
Old Jul 22, 2001 | 04:34 PM
how much would it cost to replace the stock amp..?
can i use ANY amp for the stock system?
I have a 600watt kenwood, can i use that for the stock system? AS WELL AS using it for two subs..?
Old Jul 22, 2001 | 04:36 PM
jontypes's Avatar
I have a sealed box with one xtant 10 the xtant amp I am using is made to run with the signal from a stock system
Old Jul 23, 2001 | 01:00 AM
GOT PSI?'s Avatar
It's Go-Time.
Originally posted by Dyno_CL-S:
<STRONG>
why a free air sub?? I dont like the way the bass sounds. If you like tight bass then go with some 10' sealed enclosure sub's. Again, if you want to consume the least amount then go with one and u'r sh^t will sound great. Thats my taste tho.</STRONG>
I have heard the EV 15's running free air before & the bass is not as tight as 10' but you'd be amazed how tight it really is. I'll keep u posted when it's done.
Old Jul 23, 2001 | 02:20 AM
<STRONG>how much would it cost to replace the stock amp..?
I have a 600watt kenwood, can i use that for the stock system? AS WELL AS using it for two subs..?</STRONG>
Yes, you can use the Kenwood amp. about the 2 subs, you didnt say how many channel is the Kenwood so I cannot answer that question.
Old Jul 23, 2001 | 02:38 AM
cl 01's Avatar
would one 10'with a new amp increase our bass by a lot compared with the stock system? and would it still be as crisp and clear?
Old Jul 23, 2001 | 07:43 AM
Chris's Avatar
- daemonichris -
yes
AndrewS
19
Mar 14, 2024 06:59 PM
BoricuaTL
Apr 8, 2016 01:08 PM
kb1rl
Sep 30, 2015 10:17 AM
jmaxima03
Sep 27, 2015 10:22 AM
3GTLOwns
Sep 9, 2015 09:51 PM
